Updated on 2025-04-16 GMT+08:00
Managing Cross-Account Authorization
You can view the VPCs that you have allowed other accounts to load to their cloud connections and the VPCs that you are allowed to load to your cloud connection. If you do not want other accounts to use the network instances in your account, you can cancel the authorization.
You can perform the following operations:
Viewing the VPCs that Can Be Loaded to the Cloud Connections in Other Accounts
  1. Go to the Cross-Account Authorization page.
  2. In the search area above the list, you can search for network instances by attribute or enter a keyword to search for the target network instance.
Viewing the VPCs that Other Accounts Allow You to Load
You can view the VPCs that other accounts have allowed you to load to your cloud connection.
  2. Click the Network Instances Authorized to Me tab.
  3. In the search area above the list, you can search for network instances by attribute or enter a keyword to search for the target network instance.
Canceling Cross-Account Authorization
You can cancel the authorization that allows other accounts to load your VPCs to their cloud connections.
  2. On the Network Instances Authorized by Me tab, locate the network instance and click Cancel Authorization in the Operation column.
  3. In the displayed dialog box, click OK.
After the authorization is canceled, other accounts can still use your VPCs that have been loaded to their cloud connections until these VPCs are removed from the cloud connection.
