Binding or Unbinding a Bandwidth Package to and from a Cloud Connection
Bind a bandwidth package to a cloud connection or unbind a bandwidth package from a cloud connection.
- One cloud connection can only have one bandwidth package regardless of if the cloud connection is used for communication within a geographic region or between geographic regions. For example, if network instances are in the Chinese mainland and Asia Pacific, your cloud connection can only have one bandwidth package.
- A bandwidth package can only be bound to one cloud connection.
Binding a Bandwidth Package to a Cloud Connection
- Go to the Bandwidth Packages page.
- Locate the bandwidth package you want to bind and click Bind in the Operation column.
- Select the cloud connection you want to bind the bandwidth package to.
- Click OK.
After a bandwidth package is bound to a cloud connection, you need to assign inter-region bandwidths. For details, see Assigning an Inter-Region Bandwidth.
Unbinding a Bandwidth Package from a Cloud Connection
If you no longer need a bandwidth package, you can unbind it from the cloud connection.
All inter-region bandwidths assigned based on the bandwidth package have been deleted. For details about how to delete an inter-region bandwidth, see Deleting an Inter-Region Bandwidth.
- Locate the bandwidth package you want to unbind and click Unbind in the Operation column.
