Updated on 2026-03-06 GMT+08:00
Buying a Bandwidth Package
To enable normal communication between regions in the same geographic region or different geographic regions, you need to purchase at least one bandwidth package and bind them to a cloud connection.
Bandwidth packages are used when VPCs are loaded to a cloud connection.
  • No bandwidth packages are required if two VPCs are in the same region because they can communicate with each other by default after they are loaded to the same cloud connection.
  • The geographic regions of a bandwidth package cannot be changed after it is purchased.
  1. Go to the Buy Bandwidth Package page.
  2. Configure the parameters based on Table 1 and click Next.
    Table 1 Parameters for buying a bandwidth package
    Example Value
    Basic Information
    Billing Mode
    The only option is Yearly/Monthly.
    You can purchase it by year or month as needed.
    Yearly/Monthly
    Name
    Specifies the bandwidth package name.
    The name can contain 1 to 64 characters. Only digits, letters, underscores (_), hyphens (-), and periods (.) are allowed.
    bandwidthpackage-test
    Enterprise Project
    Provides a cloud resource management mode, in which cloud resources and members are centrally managed by project.
    default
    Tag (Optional)
    Identifies the bandwidth package. A tag consists of a key and a value. You can add 20 tags to a bandwidth package.
    The tag key and value must meet the requirements listed in Table 2.
    If a predefined tag has been created on TMS, you can directly select the corresponding tag key and value.
    For details about predefined tags, see Predefined Tags.
    Bandwidth Details
    Billed By
    Specifies how you want the bandwidth package to be billed.
    Bandwidth
    Applicability
    Specifies whether you want to use the bandwidth package for communication within a geographic region or between geographic regions. There are two options:
    • Single geographic region: Use the bandwidth package between regions in the same geographic region.
    • Across geographic regions: Use the bandwidth package between regions in different geographic regions.
    Geographic Region
    Specifies the geographic regions.
    Chinese mainland
    Bandwidth (Mbit/s)
    Specifies the bandwidth you require for communication between regions, in Mbit/s. The sum of all inter-region bandwidths you assign cannot exceed the total bandwidth of the bandwidth package. Assign the bandwidth based on your network plan.
    Unit: Mbit/s
    10
    Required Duration
    Specifies how long you require the bandwidth package for.
    Auto renewal is supported.
    Cloud Connection
    Specifies the cloud connection you want to bind the bandwidth package to. There are two options:
    • Bind now
    • Bind later
    Bind later
    Table 2 Tag naming requirements
    Requirements
    Example Value
    Tag key
    For each resource, each tag key must be unique, and each tag key can only have one tag value.
    • Cannot be left blank.
    • Can contain no more than 128 characters.
    • Can contain letters in any language, digits, spaces, underscores (_), periods (.), colons (:), equal signs (=), plus signs (+), minus signs (-), and at signs (@).
    • Cannot start with _sys_ or a space or end with a space.
    bandwidthpackage_key1
    Tag value
    • Can be left blank.
    • Can contain no more than 255 characters.
    • Can contain letters in any language, digits, spaces, underscores (_), periods (.), colons (:), slashes (/), equal signs (=), plus signs (+), minus signs (-), and at signs (@).
    • Cannot start or end with a space.
    bandwidthpackage-01
  3. Confirm the configuration and submit your order.
    Go back to the bandwidth package list and locate the bandwidth package. If its status changes to Normal, you can bind the bandwidth package to the cloud connection.
    After purchasing a bandwidth package, you must bind it to the corresponding cloud connection by referring to Binding or Unbinding a Bandwidth Package to and from a Cloud Connection.
