Help Center/Cloud Connect/User Guide/Cloud Connection Operation Guide/Cloud Connections/Changing the Capacity of a Bandwidth Package Bound to a Cloud Connection
Updated on 2026-03-06 GMT+08:00
You can change the capacity of a bandwidth package bound to a cloud connection.
- Go to the Cloud Connections page.
- Click the name of the cloud connection to go to the Basic Information tab.
- Click the Bandwidth Packages tab.
- Locate the bandwidth package and click Modify Bandwidth in the Operation column.
- Set the bandwidth size as needed.
- Confirm the configurations and select I acknowledge the price change and agree to proceed.
- Click Submit.
Parent topic:Cloud Connections
