Updated on 2026-02-04 GMT+08:00
Managing Cloud Connections
You can perform the following operations to manage your cloud connections:
Viewing a Cloud Connection
You can view details about a cloud connection you have created.
  1. Go to the Cloud Connections page.
  2. View all cloud connections you have created.
  3. Locate the cloud connection you want to view and click its name to view the details, such as the basic information, network instances, bandwidth packages, inter-region bandwidths, routes, and tags.
Modifying a Cloud Connection
You can modify the name and description of a cloud connection.
  2. Locate the cloud connection you want to modify and click Modify in the Operation column.
  3. In the displayed dialog box, modify the name and description of the cloud connection.
  4. Click OK.
Deleting a Cloud Connection
You can delete a cloud connection you no longer need.
  2. Locate the cloud connection you want to delete and click Delete in the Operation column.
    If network instances have been loaded to a cloud connection, it cannot be deleted. Delete all network instances loaded to the cloud connection first. For details about how to delete network instances, see Removing a VPC from a Cloud Connection and Removing a Virtual Gateway from a Cloud Connection.
  3. In the displayed dialog box, click OK.
