Managing the Knowledge Base
After creating an intelligent Q&A bot, you need to add Q&A data to the knowledge base.
To access the knowledge base function, log in to the CBS console and click Question Answering Bot in the left navigation pane. In the Q&A bot list, click the bot ID or the Manage Bot button in the Operation column. From the left navigation pane of the Q&A Bot page, click Knowledge Base.
The knowledge base manages question categories and Q&A pairs. It includes the following functions:
Q&A Pairs
The Q&A Pairs page manages question categories and Q&A pairs. Each question belongs to a question category. A complete Q&A pair includes a question, alternative question, and answer.
- Managing question categories
Question categories are used to distinguish and manage questions in different scenarios and domains, for example, questions concerning greeting, consulting, or troubleshooting. A maximum of 1,000 question categories are allowed.
On the Q&A Pairs page, you can manage question categories in the left area, where you can perform the following operations:
- Creating a question category: Click
to create a question category.
- Deleting a question category: Select an existing question category and click
to delete it.
- Editing a question category: Select an existing question category and click
to edit it. Only the question category name can be edited.
- Updating the question category list: Click
to update the question category list.
- Searching for the desired question category: In the search text box, enter the keyword of the question category name and click
- Dragging a question category: Drag a question category or question to the same level or different levels.
- Adding a sub-category: Move the pointer to a question category and click
on the right of the category name to create a sub-category.
- Managing questions
You can create, edit, and delete questions. The operations take effect immediately. You can import Q&A pairs and modify question categories in batches. You can filter and search for questions by time and question keyword.
- Creating Q&A pairs
- Question Category: Select an existing question category from the drop-down list. You can search for created question categories. If no question category is available, create one.
- Question indicates a user question. A question contains up to 512 characters.
- Alternative Question: indicates a question similar to the user question, that is, other statements that a user may use when asking a question. Adding alternative questions helps improve Q&A performance. To add an alternative question, click
. An alternative question can contain up to 512 characters. A maximum of 200 alternative questions are allowed.
- Answer: indicates the answer to the question. Answers can be in rich text format and you can set the font, image, and source code.
- Uploading an image
- In the text box, click the image button. The Upload Image dialog box is displayed.
Figure 1 Uploading an image
- Select the location of the image to be uploaded.
Local: If you select this option, steps 3 and 4 are required.
Internet: If you select this option, enter the corresponding image link and click OK.
- Select an OBS bucket.
The image to be uploaded should be stored in a folder of the OBS bucket. To keep images properly displayed, ensure that the selected OBS bucket has the public read permission.
- Select the image to be uploaded and click OK.
- Performing operations on Q&A pairs in batches
You can modify question categories or delete Q&A pairs in batches.
- Importing Q&A pairs
- On the displayed Q&A Pairs page, click Import.
- In the displayed dialog box, set parameters as required and click OK.
File: Select the target Q&A pair file. Only one file can be imported at a time. If you do not know the data format, click the link to download the file template.
- After Q&A pairs are imported successfully, all the Q&A pairs will be displayed in the list on the Q&A Pairs page.
- Editing Q&A pairs
You can edit the existing Q&A pairs based on service changes. The following information about Q&A pairs can be edited: question category, question, and answer.
- On the Q&A Pairs page, locate the row where the target Q&A pair resides and click Edit in the Operation column.
- In the displayed Edit Q&A Pair dialog box, specify the following parameters as required: Question Category, Question, and Answer.
- Click OK.
- Deleting Q&A pairs
Certain Q&A pairs may become invalid when business changes occur. You can delete one or more Q&A pairs to release resources. Deleted Q&A pairs cannot be recovered. Exercise caution when performing this operation.
- To delete a single Q&A pair, perform the following operations: In the Q&A pair list on the Q&A Pairs page, locate the row where the target Q&A pair resides and click Delete in the Operation column.
- To delete multiple Q&A pairs in batches, perform the following operations: In the Q&A pair list on the Q&A Pairs page, select the target Q&A pairs and choose Batch Operate > Delete above the Q&A pair list.
