Viewing the Q&A Dashboard
You can improve user experience by periodically viewing the statistics and operational data of Q&A bots, and propose solutions, such as adding Q&A pairs to the knowledge base. CBS allows you to view Q&A statistics on the Dashboard page.
To access the Dashboard page, log in to the CBS console and click Question Answering Bot in the left navigation pane. In the Q&A bot list, click the bot ID or the Manage Bot button in the Operation column. Choose Operational Panel > Dashboard.
Q&A Statistics only displays Q&A data of the last three months.
Q&A Statistics
The Q&A Statistics page provides Q&A statistics of a Q&A bot. You can view statistics by time period, for example, Daily, Weekly, Monthly, Last 1 day, Last 1 week, and Last 1 month. You can also specify the target time range using the time frame.
As shown in Figure 1, Q&A statistics are displayed in terms of the following aspects:
- Q&A Ratio
Q&A types are classified into the following: Hit Questions, Recommended Questions, Chit-Chat, and Default Replies. This area displays the number of times and ratio each category of Q&A is returned in a pie chart.
- Hit Questions: questions raised by users that are the same as questions in the knowledge base. In this case, the answers are directly returned.
- Recommended Questions: questions raised by users that match multiple questions in the knowledge base. In this case, all recommended questions are returned for users to further clarify.
- Chit-Chat: questions raised by users that match chit-chat questions in the knowledge base. In this case, the answers of chit-chat questions are returned.
- Default Replies: default answers the bot replies with when it cannot understand users' questions.
- Q&A Count Trend
This area displays the Q&A count in a line chart for a specified time range.
- Q&A Ratio Trend
This area displays the Q&A ratio trend in a line chart for a specified time range.
Access Statistics
The Access Statistics page provides statistics about users' access to and usage of a Q&A bot. You can view statistics by time period, for example, Daily, Weekly, Monthly, Last 1 day, Last 1 week, and Last 1 month. You can also specify the target time range using the time frame.
As shown in Figure 2, access statistics are displayed in terms of the following aspects:
- Access Count: number of sessions between users and a Q&A bot within a specified time range. Each time the bot is activated is an instance of access.
- Unique Visitor Count: number of users accessing the Q&A bot within a specified time range.
- Average Conversation Count: average number of sessions between each user and the Q&A bot within a specified time range, which is calculated using the following formula: Total number of Q&A times between users and the Q&A bot/Total number of times users accessing the Q&A bot within a specified time range.
- Average Access Duration: average access duration of each user within a specified time range, which is expressed by seconds and calculated using the following formula: Total time duration of user access to the Q&A bot/Number of users accessing the Q&A bot within a specified time range.
- Access Count Trend: data trend of the total access quantity and unique visitor quantity within a specified time range in a line chart.
- Average Conversation Count Trend: average number of conversations within a specified time range in a line chart.
- Average Access Duration Trend: average access duration within a specified time range in a line chart.
Hot Questions
Hot questions refer to the questions that are most frequently hit in the knowledge base within a specified time range. You can view statistics by time period, for example, Last 1 day, Last 1 week, and Last 1 month. You can also specify the target time range using the time frame.
Keywords
The Keywords page displays the keywords that most frequently occur in user questions within a specified time range. You can view statistics by time period, for example, Last 1 day, Last 1 week, and Last 1 month. You can also specify the target time range using the time frame.
