Applying a Policy to a Vault
You can apply a backup or replication policy to a vault to execute backup or replication tasks at specified times or intervals. The backups or replicas can be used to restore data quickly in the event of data corruption or loss.
You can create multiple policies, but can apply only one backup or replication policy to a vault.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery. Select the corresponding backup type from the navigation pane.
- Locate the target vault and choose More > Apply Backup Policy or More > Apply Replication Policy.
Figure 1 Setting a backup policy
- Select an existing backup policy from the drop-down list or create a new one. For how to create a policy, see Creating a Backup Policy and Creating a Replication Policy.
- After the policy is successfully applied, view details in the Policies area on the vault details page.
