Deleting a Policy
If a backup or replication policy is no longer needed, for example, when a backup plan is adjusted, a policy configuration is discarded, or a test policy is cleared, you can delete it from CBR to keep the policy list clean and manageable.
Their deletion process is the same for both backup policies and replication policies.
Principles
Deleting a policy removes the policy configuration and its association with the vault. It does not delete any backups or replicas that have already been generated using the policy. After a policy is deleted, the system will no longer initiate new backup tasks based on it. For backups generated before the policy was deleted, their retention rules were calculated based on the policy configuration at the time of backup creation and are now fixed. Backups with time-based retention rules will still be automatically deleted by the system according to their original rules. To release storage space before they expire, manually delete them. Backups with quantity-based retention rules will no longer be automatically deleted by the system. To release storage space occupied by such backups, manually delete them or change the retention rules for existing backups.
At least one policy has been created.
If a backup or replication policy has been associated with a vault, you must disassociate the policy from the vault before deleting the policy.
- Log in to the CBR console. Click
in the upper left corner and select a region. - In the navigation pane, choose Policies.
- Click the Backup Policies tab, locate the row that contains the policy you want to delete, and click Delete.
Deleting a policy will not delete the backups generated based on the policy. You can manually delete unwanted backups.
- In the displayed dialog box, confirm the information, enter DELETE, and click OK.
After the policy is deleted, a message appears in the upper right corner. If the policy no longer exists in the policy list, it was deleted successfully.
