Resetting the Login Method for User admin
This topic walks you through how to reset the login method for user admin in case the admin account failed one or more multifactor authentication factors.
- Log in to the CBH console.
- Click
in the upper left corner on the displayed page and select a region.
- Locate the row containing the target instance. In the Operation column, choose More > Reset > Reset Login Method for Admin.
- In the displayed dialog box, click OK to reset the login method for user admin.
After the login mode is reset, user admin must use the username and password to log in. To configure multi-factor authentication, see Configuring Multifactor Verification.
