Using IAM Roles or Policies to Grant Access to CBH
You can use roles and policies defined in Identity and Access Management (IAM) to control access to your CBH resources. With IAM, you can:
- Create IAM users for personnel in your Huawei account based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing CBH resources
- Grant only the permissions required for users to perform a task.
- Entrust a HUAWEI ID or a cloud service to perform efficient O&M on your CBH resources.
If your Huawei Cloud account does not require individual IAM users, skip this chapter.
This section describes how to assign permissions based on roles and policies. Figure 1 shows the authorization process.
Before granting permissions to user groups, learn about system-defined permissions in for CBH. For details about the permissions of other services, see Permissions Management.
Authorization Process
- On the IAM console, create a user group and grant it permissions.
Create a user group on the IAM console, and attach the CBH ReadOnlyAccess policy to the group.
- Create an IAM user and add it to the user group.
Create a user on the IAM console and add it to the user group created in 1.
- Log in as the IAM user and verify permissions.
In the authorized region, perform the following operations:
- Hover over Service List and choose Cloud Bastion Host. On the CBH console, click Buy CBH Instance in the upper right corner. If the CBH instance cannot be purchased (assume that the current permission contains only CBH ReadOnlyAccess), the CBH ReadOnlyAccess policy is in effect.
- Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, the CBH ReadOnlyAccess policy is in effect.
Example CBH Custom Policies
Custom policies can be created to supplement the system-defined policies of CBH. For the actions supported for custom policies, see .
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Edit JSON policies from scratch or based on an existing policy.
For details, see Creating a Custom Policy. The following lists examples of common CBH custom policies.
- Example 1: Allowing users to change CBH instance specifications and upgrade CBH instance version.
1 2 3 4 5 6 7 8 9 10 11 12
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "cbh:instance:upgrade", "cbh:instance:alterSpec" ] } ] }
- Example 2: Denying a user request of restarting a CBH instance
A deny policy must be used together with other policies. If the policies assigned to a user contain both Allow and Deny actions, the Deny actions take precedence over the Allow actions.
The following method can be used to create a custom policy to disallow users who have the CBH FullAccess policy assigned to restart a CBH instance. Assign both CBH FullAccess and the custom policies to the group to which the user belongs. Then the user can perform all operations on CBH except restarting a CBH instance. The following is an example of a deny policy:
{ "Version": "1.1", "Statement": [ { "Effect": "Deny", "Action": [ "cbh:instance:reboot" ] } ] }
- Example 3: Defining permissions for multiple services in a policy
A custom policy can contain the actions of multiple services that are of the global or project-level type. The following is an example policy containing actions of multiple services:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "cbh:instance:create" ] }, { "Effect": "Allow", "Action": [ "vpc:subnets:get" ] }, { "Effect": "Allow", "Action": [ "ecs:cloudServerFlavors:get" ] } ] }
CBH Resources
A resource is an object that exists within a service. CBH resources include instances (instanceId). When creating a custom policy, you can select a specific resource by specifying the resource path.
| Specific Resource | Name | Path |
| instanceId | Instance ID | [Format] CBH:*:*:instanceId:Instance ID [Description] For instance resources, CBH automatically generates the prefix (CBH:*:*:instanceId:) for resource paths. For the path of a specific instance, add the instance ID to the end. You can also use an asterisk * to indicate any instance. Example: CBH:*:*:instanceId:The asterisk (*) indicates any CBH instance. |
