Updated on 2025-09-04 GMT+08:00
Releasing an Instance
You can unsubscribe from a CBH instance if you no longer need it.
You have stopped all operations in the CBH system and unbound the EIP from the instance you want to unsubscribe from.
- Log in to the CBH console.
- Click
in the upper left corner on the displayed page and select a region.
- Locate the row containing the target instance and choose More > Release in the Operation column.
- Confirm the information and click OK.
- Complete the unsubscription.
- You can only unbind an EIP from a CBH instance. To release an EIP, go to the EIP management page and manually release it.
- After the unsubscription request is submitted and approved, you will get a refund for the remaining required duration within a specified period. For more details, see Unsubscription Rules.
- It takes about one minute to complete the unsubscription.
- After you unsubscribe from a CBH instance, you cannot log in to the mapped CBH system and system data cannot be retrieved. Exercise caution when performing this operation.
- After you unsubscribe from a bastion host, the residual resources will be automatically cleared at 03:00 the next day. If you want to delete a security group, wait until the residual resources are cleared.
Parent topic: Managing Instances
