Updated on 2025-09-29 GMT+08:00
Container Resource Management
After a container is managed by a bastion host, you can delete the container or modify the container information at any time.
  • You must have the permission on the container module.
  • To use this function, the bastion host version must be V3.3.48.0 or later.
Editing a Container
  1. Log in to your bastion host.
  2. Choose Resource > Cloud Service. The Cloud Service is displayed.
  3. Click Manage in the Operation column of the container whose information is to be modified. The Container Detail page is displayed.
    Figure 1 Container detail
  4. Click Edit on the right of the Basic Info row. In the dialog box that is displayed, modify the container information. For details about the parameter rules, see Table 1.
  5. After modifying the parameters, click OK. The container information is modified.
Delete Containers
  3. Click Delete in the Operation column of the container to be deleted.
  4. In the dialog box that is displayed, click OK. The container is deleted.
