Help Center/ Cloud Bastion Host/ User Guide/ Maintenance Management/ System Maintenance/ System Configuration Backup and Restoration (Backup&Restore)
Updated on 2025-10-28 GMT+08:00
To ensure that the system configuration data is not lost, enable the automatic backup function or periodically back up the system configuration data.
This section describes how to back up and restore system configurations and how to manage the backup files
The backup files are stored on your bastion host. So they will use some space. You can check the backup file size by date in the backup list.
  • A system configuration backup file can only be used for the bastion host that generates it.
  • Only system configuration parameters can be backed up. System data generated during O&M cannot be backed up. For details about system data backup, see Data Maintenance
You have the management permissions for the System module.
Backing Up System Configuration Data
  1. Log in to your bastion host.
  2. Choose System > System Maintain > Backup&Restore.
  3. Enable auto backup.
    In the Config Backup area, enable Auto. The system will automatically back up the configuration at 00:00 every day.
  4. Start a backup job immediately.
    1. In the Config Backup area, click New.
    2. In the displayed dialog box, enter remarks to distinguish backup files.
    3. Click OK to start the backup. After the backup is complete, you can view the backup file in the backup list.
Restoring System Configurations
  3. Restore the system configuration. Select any of the following methods:
    • One-click system configuration restoration
      Before you start, ensure that a system configuration backup file is ready.
      1. In the Config Backup area, select the backup file you want to use.
      2. In the Operation column, click Restore.
    • Using a local backup file to restore system configurations
      1. In the Config Restore area, click Upload.
      2. In the displayed dialog box, select a backup configuration file that has been downloaded.
      3. After the backup file is uploaded, click OK to start the restoration.
  4. Refresh the page. After the system is restored, you are required to log in to the system again.
Managing Backup Files
You can download and delete system configuration backup files to save more storage space.
  2. Choose System > System Maintain > System Status.
  3. Download a backup file.
    2. In the Operation column, click Download to download the backup file.
  4. Delete a backup file.
    2. In the Operation column, click Delete to delete the backup file to release storage space.
