Historical Session Overview
Each time an operation is finished, a historical session is generated to record the specific operations performed by the operator. Auditors can view these historical sessions to check whether operators performed any non-compliant operation. Historical sessions can be audited in video or text format. You can choose either format as needed.
Audit Formats
| Type | Description | Supported Protocol |
| Video recording audit | All activities performed by operators after they log in to managed resources through a bastion host are recorded as video recordings. Auditors can download and playback them in just a few clicks. |
| Text audit | All activities performed by operators after they log in to managed resources through the bastion host are recorded as detailed text data. Auditors can view the records online or export historical session records in just a few clicks. The recorded text data is classified into the following types:
References
