Exporting User Information
You can export user information in batches so that you can have a local backup and edit basic user information easily.
- You can export user information about login name, authentication method, authentication server, username, mobile number, email address, role, department, and user group.
- To ensure user account security, passwords cannot be exported.
You have the operation permissions for the User module.
- Log in to your bastion host.
- Choose
. The user list page is displayed. You can query a user using the quick search or advanced search function.
- Quick search: Enter a keyword in the search box and search for a user by login name or username.
- Advanced search: Click Advanced next to text box and enter keywords in the corresponding attribute search boxes to search for users.
- Select users you want to export. If no users are selected, all users will be exported by default.
- Click
in the upper right corner. Confirm the export in the displayed dialog box.
- Set an encryption password to encrypt the exported file.
- Enter your password.
When you use an IAM, SAML, or Azure AD account to log in to a bastion host, if the system displays a message indicating that the local password is not set, set the local password in the Profile center or contact the administrator. For details, see Changing Your Password/Setting a Local Password.
- Select the CSV or Excel format.
- Click OK. After the task is created, click Go to Download Center. If the export progress reaches 100%, click Download in the Operation column. Then you can view the exported user accounts in the downloaded file.
