- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Show all
Cloud Storage Description
CAE supports parallel file system and bucket. Table 1 describes the features and application scenarios of them.
Dimension |
OBS Parallel File System |
OBS Bucket |
Definition |
Parallel File System (PFS) is a high-performance system with access latency in milliseconds. Provided by OBS, PFS supports bandwidth up to the TB/s level and millions of IOPS for processing high-performance computing (HPC) workloads. |
A bucket is a container for storing objects in OBS. It provides massive, secure, reliable, and cost-effective data storage. |
Data storage logic |
Stores files but supports object APIs. That is, you can process files the same way you process objects, implementing the interworking between objects and files. |
Stores objects. Files directly stored automatically generate the system metadata, which can also be customized by users. |
Features |
Shared storage and user-mode file system. High-performance storage services are provided. |
Shared storage and user-mode file system. You can configure the object storage class as required. |
Application scenario |
High-performance computing and media asset archiving, such as video surveillance, online video on demand (VoD), HPC, and big data |
Big data analytics, static website hosting, VoD, gene sequencing, intelligent video surveillance, backup and archiving, and enterprise cloud boxes (web disks) |
