Updated on 2025-07-10 GMT+08:00
Rolling Back a Component
You can roll back to a historical version and configuration. (A version number is generated for each component configuration. The number is the same as the current one, but the time is different.)
  1. Log in to CAE.
  2. Choose Components.
  3. Select the target component and click More > Roll back in the Operation column.
  4. Select a rollbak version.
    Figure 1 Selecting a rollback version
  5. Confirm the component configuration and code source of the rollback version, and click Roll Back Now.
    Figure 2 Confirming information
