Updated on 2025-10-22 GMT+08:00
Stopping a Component
You can stop a component that is not used. After a component is stopped, no fee is generated and its associated applications cannot be used.
  • Components in the Not deployed and Not ready states cannot be stopped.
  • Do not stop a component when it is being scaled. Disable the AS policy before the operation. For details, see Disabling an AS Policy.
  • When a component is being stopped, AS policies cannot be added or enabled for the component.
  1. Log in to CAE.
  2. Choose Components.
  3. Select the target component and click More > Stop in the Operation column.
    Figure 1 Stopping a component
  4. In the displayed dialog box, click OK.
