Updated on 2024-09-20 GMT+08:00
Applying to Join Carrier Partner Program
You have joined the Cloud Solution Provider Program.
  1. Use your account to log in to Huawei Cloud.
  2. Click Partner Center in the drop-down list of your account name in the upper right corner.
  3. Choose Partner Programs > Huawei Cloud Partner Programs in the menu on the top.
  4. Select Carrier Partner Program and click Join Now.
  5. Upload required qualification files and click Submit.
    • You can also click Save Draft.
    • On the Partner Programs > Requested Partner Programs page, you can view, submit, or delete the draft applications.
    • On the HUAWEI CLOUD Partner Programs page, you can edit your draft applications.
  6. A message indicating that your application has been submitted successfully is displayed.
