Updated on 2025-11-28 GMT+08:00
Role Selection
After joining HCPN, you can select a development path and obtain according benefits.
  1. Use your account to log in to Huawei Cloud.
  2. Click Partner Center in the drop-down list of your account name in the upper right corner.
  3. Click Select Development Path in the Development Paths Selected area on the Home page displayed by default.
  4. Find Software Partner on the displayed page and click Select.
    There are different development paths and corresponding cooperation programs available for your choice.
  5. Click OK on the displayed page.
    • If there is an account of your company that has already been used to join the software partner development path, other accounts who want to join this development path must obtain approval from the Huawei Cloud ecosystem manager.
    • You cannot join the Cloud Solution Provider Program after joining this development path. Register a new account to join the program.
  6. Verify that a message, indicating that you have joined the software partner development path, is displayed. Then, click View Details, and choose to request role validation.
  7. View the stage you are at now during entire partner journey and check the minimum requirements for role validation.
    • If you have joined the software partner development path by mistake, you can exit the path before role validation.
    • You are not allowed to exit the development path if your current account:
      1. Has already joined a partner program.
      2. Has completed role validation.
      3. Has completed competency differentiation certification.
      4. Has requested certification for cloud software solutions.
      5. Has requested certification for advanced cloud software solutions.
      6. Has requested test coupons.
      7. Has requested exam vouchers.
      8. Has requested Market Development Fund (MDF).
      9. Has requested Funding Head (FH).
