Applying to Join HMS Ecosystem Support Program
After becoming an HCPN partner, Huawei Cloud enterprise customers can apply to join the HMS Ecosystem Support Program in the Partner Center. Click here to view the benefits that HMS Ecosystem Support Program offers.
Important Notes
Enterprise customers cannot apply to join the HMS Ecosystem Support Program if their Huawei Cloud accounts are in one of the following situations:
- The consumption of the account exceeds 100 USD.
- The account has a special contract that is taking effect.
- After joining the HMS Ecosystem Support Program, do not apply for special commercial contracts. Otherwise, the account will automatically exit the program.
- After an enterprise joins the HMS Ecosystem Support Program, the consumption of an HMS partner is collected on the fifth day of each month. If the consumption meets the requirements, Huawei Cloud automatically issues cash coupons to the HMS partner.
- You have registered a Huawei Developer account.
Each Huawei Developer account can be used only once to apply to join HMS Ecosystem Support Program.
- Use your account to log in to Huawei Cloud.
- Click Partner Center in the drop-down list of your account name in the upper right corner.
- Choose Partner Programs > Huawei Cloud Partner Programs in the menu on the top.
- Select HMS Ecosystem Support Program and click Join Now.
- Enter your Huawei developer account.
- Click Submit.
You can view the progress on the Requested Partner Programs page.
