Updated on 2026-07-21 GMT+08:00
Disassociating from a Partner
If a customer associated with a partner in the reseller model wants to disassociate from the partner, the customer can request disassociation in My Account.
  1. Only three disassociation requests can be initiated by a customer within a three-month period.
  2. After the disassociation, the customer shall promptly update their account information and configure a valid payment method. Failure to do so may result in the initiation of a grace period and retention period, consequent to payment failure. During the grace period, the customer can access and use only some of their resources. During the retention period, they cannot access or use their resources but the data stored in the resources can be retained. If the renewal is still not completed or the outstanding amount is still not paid off when the retention period ends, the stored data will be deleted and the cloud service resources will be released.
  3. For customers associated with a partner in the Reseller model, they cannot apply to disassociate from the partner if they are in one of the following conditions:
    • If the account of a customer is an enterprise master account, and the account is associated with independent accounting members, the customer needs to disassociate from all independent accounting members before disassociating from the partner.
    • If the customer account is frozen, the customer must contact the partner to unfreeze the account, and then apply for disassociation.
    • If the customer account and resources are frozen, the customer must contact the partner to unfreeze the account and resources, and then apply for disassociation.
    • A customer has valid RIs or a partner support plan. In this case, the customer needs to unsubscribe from the RIs or the partner support plan before disassociating from the partner.
    • The customer has not set the currency. To disassociate from a partner, the customer needs to go to the account center and set a currency first.
    • A customer has an effective special commerce contract. In this case, the customer needs to contact the partner offline to handle it before applying for canceling the association relationship.
    • The customer has a valid support plan. In this case, the customer needs to unsubscribe from the support plan before disassociating from the partner.
    • If the customer account is an enterprise master account that has member accounts with valid service support plans, the customer needs to unsubscribe from those plans before disassociating from the partner.
  4. If the customer is a Huawei Cloud NA customer, the disassociation request needs to be pre-reviewed by Huawei. The pre-review takes a maximum of three working days.
  1. Go to the My Partner page.
  2. Click More Operations > Disassociate at the bottom of the page to initiate a disassociation request.
  3. Verify your account and confirm the disassociation.
    • If the account passes the check, select I understand the preceding statement and confirm to disassociate from the partner account, and click Disassociate.
    • If the account fails the check, handle the failed items as prompted. Then check the account again.
  4. Obtain the verification code, enter it, and click OK.
    • If there is only an email address linked to your account, click Send Code.
    • If there is only a mobile number linked to your account, click Send Code.
    • If both a mobile number and an email address are linked to your account, you have to choose either email or mobile number to receive the verification code, and then click Send Code.
  5. Specify the reason.
    Select the reason for disassociating from the partner and click Submit.
  6. Verify that the disassociation request has been submitted successfully.
    The system displays a message indicating that the request for disassociating from the partner has been submitted successfully. After your partner completes the processing, you will be notified of the processing result.
    If you are a Huawei Cloud NA customer, the disassociation request needs to be pre-reviewed by Huawei. The pre-review takes a maximum of three working days. You can also contact the pre-reviewer by referring to Other Operations.
  1. Go to the My Partners page and click process.
  2. Verify you account.
    • If the account passes the check, read the precautions carefully.
      If you do not agree to the disassociation, you can go to the next step even if the account fails the check.
  3. Confirm whether to agree to the disassociation. The disassociation request initiated by the partner will be processed.
  • Viewing operation logs
    Access My Partner > Partner Information and click More Operations > Operation Log. On the displayed page, you can view the logs of association and disassociation operations.
    For a disassociation request that needs to be pre-reviewed by Huawei, you can move the cursor to the question mark next to the Under pre-review by Huawei status to view the pre-reviewer and their email address. You can also move the cursor to the question mark next to the Pre-review failed status to view the reason for the failure. You can then handle the issue as prompted and submit a disassociation request again.
