Updated on 2025-06-30 GMT+08:00
Viewing Traces
CTS allows you to record customer related operations that are performed by calling APIs. CTS stores operation records for the last seven days.
This section describes how to view the operation records on the CTS console.
  1. Sign in to the management console.
  2. Click in the upper left corner, and select the target region and project.
  3. Choose Service List > Management & Governance > Cloud Trace Service.
  4. Choose Trace List in the navigation pane.
  5. In the upper right corner, select a time range from Last 1 hour, Last 1 day, and Last 1 week, or select Customize to specify a time range as needed. And specify filter criteria as needed. The following filter criteria are available: You can filter operation events with a combination of four criteria:
    • Trace Type, Trace Source, Resource Type, and Search By.
      Select a filter criterion from the drop-down list of Search By.
      If you select Trace name, you need to select a specific trace name.
      If you select Resource ID, you need to enter a specific resource ID.
      If you select Resource name, you need to enter a specific resource name.
    • Operator: Select a specific operator (a user other than tenant).
    • Trace Status: Select Normal, Warning, or Incident.
    • Time Range: You can query traces generated during any time range of the last seven days.
  6. Expand the trace to view details.
    Figure 1 Trace details
  7. Locate a trace and click View Trace in the Operation column.
    For details about CTS, see Cloud Trace Service User Guide.
