Technical Certification
After the software or solution is built and released, you can submit an application for technical certification. After the technical certification review, the software or solution gets the advanced cloud software certification and the corresponding ecosystem program certification, and you can gain access to the associated benefits.
- Use your account to log in to Huawei Cloud.
- Click Partner Center in the drop-down list of your account name in the upper right corner.
- Choose Build > Advanced Cloud Software Solutions in the menu on the top.
- On the Ecosystem Program Software Solutions tab, select a solution in the Admission certification passed state and click Request Technical Certification in the Operation column.
- On the displayed page, upload required technical certification materials according to the template and click Submit.
- After the application is submitted, the system displays a message indicating that the solution technical certification application has been submitted successfully.
- Click the solution name on the Ecosystem Program Software Solutions tab to switch to the certification details page where you can check the review progress.
- Technical certification failed: If the technical certification failed, you can modify the certification information based on the review comments and submit the technical certification application again.
- Technical certification passed: If the solution passes the technical certification, you can request Market Development Fund (MDF).
Available Benefits
If you have applied to join an ecosystem program for your software products or solutions and these products or solutions have passed the technical certification, you can request the corresponding benefits listed below:
Benefit |
AI compute Service/Pangu Large Models |
Kunpeng Cloud |
GaussDB |
Migration of HarmonyOS Applications to the Cloud |
MDF |
Up to $30,000 USD/solution |
N/A |
