Admission Certification
Once your software product or solution is initiated, you can apply for admission certification. Upon approval, you can gain access to the relevant ecosystem program and its associated benefits.
- After joining this program, wait until related data is synchronized and then apply for the ecosystem solution certification.
- If no solution is available, you can create a baseline solution.
- Use your account to log in to Huawei Cloud.
- Click Partner Center in the drop-down list of your account name in the upper right corner.
- Choose Build > Advanced Cloud Software Solutions in the menu on the top.
- Select the Ecosystem Program Software Solutions tab and click Certify.
- Specify the ecosystem program certification information, upload admission certification materials, and click Next.
- If you select Baseline solution for Scheme Sources, eligible solutions are limited to baseline solutions successfully initiated.
Ecosystem programs:-
Ascend Cloud/Pangu Large Models:
1. Applications and software solutions built based on Ascend Cloud, Ascend-based Huawei Cloud Stack infrastructure, or Pangu Large Models
2. AI platform tool software built based on Ascend Cloud or Ascend-based Huawei Cloud Stack infrastructure
- Kunpeng Cloud: Applications and software solutions built based on Kunpeng Cloud services
1. Applications and software solutions built based on GaussDB
2. Database tool software built based on GaussDB
Migration of HarmonyOS applications to the cloud:
1. HarmonyOS applications, atomic services, and solutions built based on Huawei Cloud services
2. HarmonyOS application cloudification tools built based on Huawei Cloud services
- Enter the contact information and click Certify.
- The system displays a message indicating that your admission certification application has been submitted successfully.
- Click the solution name on the Ecosystem Program Software Solutions tab to switch to the certification details page where you can check the review progress.
- Admission certification failed: If the admission certification failed, you can modify the certification information based on the review comments on the details page and submit the admission certification application again.
- Admission certification passed: If you pass the admission certification, you can request test coupons.
Available Benefits
If you have applied to join an ecosystem program for your software products or solutions and these products or solutions have passed the admission certification, you can request the corresponding benefits listed below:
Benefit |
Ascend Cloud/Pangu Large Models |
Kunpeng Cloud |
GaussDB |
Migration of HarmonyOS Applications to the Cloud |
Non-Recurring Engineering (NRE) |
Up to $80,000 USD/solution |
Test Coupons |
Up to $90,000 USD/solution |
Up to $40,000 USD/solution |
N/A |
N/A |
