Ecosystem Program Software Solution Certification
Ecosystem program software solution certification consists of admission certification and technical certification.
Admission certification: Once your software product or solution is initiated, you can apply for admission certification. Upon approval, you can gain access to the relevant ecosystem program and its associated benefits.
Technical certification: After the software or solution is built and released, you can submit an application for technical certification. After the technical certification review, the software or solution gets the advanced cloud software certification and the corresponding ecosystem program certification, and you can gain access to the associated benefits.
- You have joined Special Program for Huawei Cloud Software Partners' Ecosystems on Ascend Cloud/Pangu Large Models, Kunpeng Cloud, GaussDB, or HarmonyOS Applications.
- A baseline solution has been initiated.
