Help Center/ Partner Center/ User Guide/ Partner Build Management/ Creating a Cloud Software Solution
Updated on 2025-11-24 GMT+08:00
You have joined the software partner development path.
  1. Use your account to log in to Huawei Cloud.
  2. Click Partner Center in the drop-down list of your account name in the upper right corner.
  3. Choose Build > Cloud Software Solutions in the menu on the top. Click Create Cloud Software Solutions on the page displayed by default.
  4. Specify solution details and click Next.
  5. Enter the contact information and click Certify.
  6. A message is displayed indicating that the solution has been successfully submitted for certification.
  7. After the solution has been submitted for certification, you can click View Details in the Operation column on the Cloud Software Solutions page to check the review progress.
    A cloud software solution will be valid for 12 months as of the date when this solution is validated and approved.
Re-certifying a Cloud Software Solution
Partners can initiate the re-certification process for a cloud software solution 60 days before its expiration. The solution will be valid for an additional year from the date of successful re-certification.
  1. On the Cloud Software Solutions page, select a solution that is about to expire or has expired, and click Recertify in the Operation column.
  2. On the displayed page, you are only allowed to modify the solution version and materials.
  3. Enter the contact information and click Certify.
Downloading a Solution Certificate
If the solution you submitted for certification is approved, you can download corresponding certificate on the Certified tab page.
