Managing Invited Customers
The reseller can view the customer association status and track the association progress in Partner Center after sending an invitation link to a customer.
Viewing the Association Failure Cause
- Access the History Records page.
a) Log in to Huawei Cloud as a reseller.
b) Click Partner Center in the drop-down list of your account name in the upper right corner.
c) In the top navigation, select Sales > Leads and Opportunities > Customer Development. On the displayed page, click the History Records tab.
- In the customer list, filter customers whose status is Association failed. Hover the cursor over
next to Association failed to view the cause of the association failure.
Association Failure Causes and Suggested Operations
Message |
Suggested Operation |
The system is busy. Try later. |
Contact the customer service. |
The invitation link does not exist. |
Send the invitation email again. |
The invitation link has expired. |
The invitation code has been used. |
The invitation link has been used. |
Prepaid partners cannot develop customers in reseller model. |
Failed to associate with the partner because the customer has been registered by another partner. |
The customer cannot be associated with a partner in this condition. |
Failed to set the customer to a partner's customer because the customer is already a partner or is applying for becoming a partner. |
Failed to associate with the partner because the customer already associates with another partner. |
Failed to associate with the partner because the customer has a special contract. |
Failed to associate with the partner because the customer uses a Huawei internal account. |
Failed to associate with the partner in the reseller model because the customer has associated with an independent accounting member account as the enterprise master account. |
The customer cannot be associated with a partner in Reseller model. |
Failed to associate with the partner in the reseller model because the customer was using an enterprise member account to do so. |
Failed to associate with the partner because the customer has a consumption record. |
Remind the customer to submit a service ticket or contact the customer service to associate with the partner. |
Failed to associate with the partner because the top-up account has a balance and the outstanding invoice amount is greater than the limit. |
Failed to associate with the partner because the customer registration time exceeds the limit. |
Failed to associate with the partner because the customer has overdue payment. |
Remind the customer to top up the account and settle the overdue payment and then submit a service ticket or contact the customer service to associate with the partner. |
Failed to associate with the partner by reseller model because the bill run of the customer's credit account is created and the account has overdue payment. |
Remind the customer to settle all the overdue payments and then submit a service ticket or contact the customer service to associate with the partner. |
Association not supported. This customer has valid service support plans. |
Remind the customer to unsubscribe from the service support plans and then submit a request for association. |
Association not supported. This enterprise member account has valid service support plans. |
Remind the customer to unsubscribe from the service support plan of this member account and then submit a request for association. |
Resending an invitation email
If a pre-registered customer is not associated with the account or the invitation email has expired, resellers can send an invitation email again. If a pre-registered customer fails to be associated with the account, resellers can send an invitation email again after modifying the information as prompted.
- After determining the target customer, click Resend Invitation in the Operation column of the customer. Or you can select one or more target customers and click Resend Invitation above the customer list.
- In the displayed dialog box, confirm the customer information and click OK.
Viewing Invited Customers
On the History Records page, resellers can view customers who have received invitations and those who have accepted invitations and registered with Huawei Cloud.
- Set search criteria to query for the invited customers to be viewed.
- You can check the invited customers by customer full name, customer information (customer name and account), custom tag, account manager's account name, remarks, and email address.
- You can also filter the customer list by invitation method and status.
- Click
to view information about invited customers.
- The email address in the History Records is the one entered during partner registration.
- You can click the eye icon next to a field to view or hide the complete content of the field. The content is hidden by default. For example, you can click the eye icon next to Mobile Number to view or hide the complete content of the mobile number.
Exporting Invited Customers
Resellers can export all records of invited customers to view them offline.
- Click Export All to export records of all invited customers.
When using the export function of Partner Center, please note that any sensitive information, such as customer names, mobile numbers, and email addresses, will be anonymized.
- Choose Export > View Export to switch to the Export History page.
- When the export status is updated to Completed, click Download in the Operation column to download the record to your local PC. Then you can view all invited customers offline.
