Viewing a Customer's Resources
A partner can view each associated customer's pay-per-use or yearly/monthly resources, reserved instances, and savings plans.
- Sign in to Huawei Cloud as a partner.
- In the drop-down list of your account name, click Partner Center to go to the Partner Center.
- On the top navigation bar, select Sales > Customers > Customer Management.
- On the Customer Management page, set the search criteria for a fuzzy search. Select a target customer and choose More > View Resource to enter the resource management page.
- View the resources purchased by customers.
- View yearly/monthly resources.
On the Yearly/Monthly Resources page, set the search criteria and query the desired yearly/monthly resource records.
- Click Export to export all yearly/monthly resource records of a customer.
- Click
to check instance information and resource status.
- Click
to check associated resources.
- View pay-per-use resources.
On the Pay-per-use Resources tab, set search options to query target pay-per-use resources.
Click Export to export all pay-per-use resource records of a customer.
- View reserved instances.
On the Reserved Instances tab, set search options to query target instances.
- View savings plans.
On the Savings Plans tab, set search options to query target savings plans.
