Help Center/ Bare Metal Server/ User Guide/ Security/ Security Group/ Security Group Configuration Examples
Updated on 2022-12-19 GMT+08:00
Case 1: BMSs in Different Security Groups Need to Communicate with Each Other Through an Internal Network
  • Scenario
    Resources on a BMS in a security group need to be copied to a BMS in another security group. The two BMSs are in the same VPC. Then, you can enable internal network communication between the two BMSs and copy resources.
  • Security group configuration
    In the same VPC, BMSs associated with the same security group can communicate with one another by default, and no additional configuration is required. However, BMSs in different security groups cannot communicate with each other by default. You must add security group rules to enable the BMSs to communicate with each other through an internal network.
    Protocol
    Direction
    Port Range/ICMP Protocol Type
    Source
    Protocol to be used for internal network communication. Supported values are TCP, UDP, ICMP, and All.
    Inbound
    Port number range or ICMP protocol type
    IPv4 address, IPv4 CIDR block, or another security group ID
Case 2: Only Specified IP Addresses Can Remotely Access BMSs in a Security Group
  • Scenario
    To prevent BMSs from being attacked, you can change the port number for remote login and configure security group rules that allow only specified IP addresses to remotely access the BMSs.
    To allow IP address 192.168.20.2 to remotely access Linux BMSs in a security group over the SSH protocol and port 22, you can configure the following security group rule.
    Protocol
    Direction
    Port Range
    Source
    SSH (22)
    Inbound
    22
    For example, 192.168.20.2
Case 3: Remotely Connecting to a Linux BMS Through SSH
  • Scenario
    To remotely connect to a Linux BMS through SSH, you need to add a security group rule.
    The default security group comes with this rule. If you use the default security group, you do not need to configure the rule again.
    Protocol
    Direction
    Port Range
    Source
    SSH (22)
    Inbound
    22
    0.0.0.0/0
Case 4: Remotely Connecting to a Windows BMS Through RDP
  • Scenario
    To remotely connect to a Windows BMS through RDP, you need to add a security group rule.
    Protocol
    Direction
    Port Range
    Source
    RDP (3389)
    Inbound
    3389
    0.0.0.0/0
Case 5: Pinging a BMS from the Internet
  • Scenario
    To ping BMSs from each other to check connectivity, you need to add a security group rule.
    Protocol
    Direction
    Port Range
    Source
    ICMP
    Inbound
    All
    0.0.0.0/0
