Resource Location
Some resources are available in all regions around the globe, while others are only available in specified regions or AZs.
| Resource | Type | Description |
| Account of Huawei Cloud | Global | You can use the same Huawei Cloud account across all regions. |
| Predefined tags | Global | You can use the same predefined tag in all regions. |
| Key pair | Global or regional | A key pair you create on the management console is associated with the region where it is created. You can create your own RSA key pair and import it into the region where you want to use it. Therefore, you can upload a key pair to each region to use it globally. For details about key pairs, see Using an SSH Key Pair. |
| Resource identifier | Regional | Each resource identifier (such as instance ID, EVS disk ID, and VPC ID) is associated with a region and can be used only in the region where the resource is created. |
| User-defined resource name | Regional | Each resource name (such as the security name and key pair name) is associated with a region and can be used only in the region where the resource is created. Although you can create resources with the same name in different regions, the resources are not associated with each other. |
| VPC | Regional | A VPC is associated with a region and can only be associated with instances in the same region. |
| EIP | Regional | An EIP is associated with a region and can only be associated with instances in the same region. |
| Security group | Regional | A security group is associated with a region and can only be allocated to instances in the same region. The security group rule cannot be used to enable communication between instances in different regions. |
| Image | Regional | An image is associated with a region and can only be associated with instances in the same region. The image can be a public, private, or shared image. |
| Instance | AZ | An instance is associated with an AZ, but the instance ID is associated with a region. |
| Disk | AZ | A disk is associated with an AZ and can only be attached to instances in the same AZ. |
| Subnet | AZ | A subnet is associated with an AZ and can only be associated with instances in the same AZ. |
