Updated on 2026-11-24 GMT+08:00
Quota Adjustment
What Is Quota?
To prevent resource abuse, quotas are enforced for each service resource on the platform to limit the quantity and capacity of resources you can use, such as the maximum number of BMSs or EVS disks you can create.
If the existing resource quota cannot meet your service requirements, you can apply for a higher quota.
The BMS service has no independent quota. It shares the number of instances, CPU cores, and memory with the ECS service. You can view BMS quota in the Elastic Cloud Server row.
How Do I View My Quotas?
  2. Click in the upper left corner and select the desired region and project.
  3. In the upper right corner of the page, choose Resources > My Quotas.
    The Quotas page is displayed.
    Figure 1 My Quotas
  4. View the used and total quota of each type of resources on the displayed page.
    If a quota cannot meet service requirements, apply for a higher quota.
How Do I Apply for a Higher Quota?
  2. In the upper right corner of the page, choose Resources > My Quotas.
    Figure 2 My Quotas
  3. Click Increase Quota in the upper right corner of the page.
    Figure 3 Increasing quota
  4. On the Create Service Ticket page, configure parameters as required.
    In the Problem Description area, fill in the content and reason for adjustment.
  5. After all necessary parameters are configured, select I have read and agree to the Ticket Service Protocol and Privacy Statement and click Submit.
