Help Center/ Bare Metal Server/ User Guide/ Cloud Eye Monitoring/ Monitored Metrics (with Agent Installed)
Updated on 2026-08-24 GMT+08:00
This section describes monitoring metrics reported by BMS to Cloud Eye as well as their namespaces and dimensions. You can use the management console or APIs provided by Cloud Eye to query the metrics of the monitored objects and alarms generated for BMS.
Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is instance_id,mount_point, instance_id indicates level 0 and mount_point indicates level 1.
The Agent has been installed. For details, see Installing the Agent.
Namespace
SERVICE.BMS
OS Metrics: CPU
Table 1 CPU metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Interval (Raw Data)
cpu_usage
(Agent) CPU Usage
CPU usage of the monitored object
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) value.
  • Windows: Obtain the metric value using the Windows API GetSystemTimes.
0-100
N/A
instance_id
1 minute
cpu_usage_idle
(Agent) Idle CPU Usage
Percentage of time that CPU is idle
0-100
N/A
instance_id
1 minute
cpu_usage_other
(Agent) Other Process CPU Usage
Percentage of time that the CPU is used by other processes
  • Linux: Other Process CPU Usage = 1 – Idle CPU Usage (%) – Kernel Space CPU Usage (%) – User Space CPU Usage (%)
  • Windows: Other Process CPU Usage = 1 – Idle CPU Usage (%) – Kernel Space CPU Usage (%) – User Space CPU Usage (%)
0-100
N/A
instance_id
1 minute
cpu_usage_system
(Agent) Kernel Space CPU Usage
Percentage of time that the CPU is used by kernel space
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) sy value.
0-100
N/A
instance_id
1 minute
cpu_usage_user
(Agent) User Space CPU Usage
Percentage of time that the CPU is used by user space
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) us value.
0-100
N/A
instance_id
1 minute
cpu_usage_nice
(Agent) Nice Process CPU Usage
Percentage of time that the CPU is used by the Nice process
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) ni value.
  • Windows is not supported currently.
0-100
N/A
instance_id
1 minute
cpu_usage_iowait
(Agent) iowait Process CPU Usage
Percentage of time during which the CPU is waiting for I/O operations to complete
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) wa value.
0-100
N/A
instance_id
1 minute
cpu_usage_irq
(Agent) CPU Interrupt Time
Percentage of time that the CPU is servicing interrupts
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) hi value.
0-100
N/A
instance_id
1 minute
cpu_usage_softirq
(Agent) CPU Software Interrupt Time
Percentage of time that the CPU is servicing software interrupts
  • Linux: Check metric value changes in file /proc/stat in a collection period. Run the top command and check the %Cpu(s) si value.
0-100
N/A
instance_id
1 minute
OS Metrics: CPU Load
Table 2 CPU load metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
load_average1
(Agent) 1-Minute Load Average
CPU load averaged from the last 1 minute
Linux: Obtain the metric value from the number of logic CPUs in load1/ in file /proc/loadavg. Run the top command and check the load1 value.
≥0
N/A
N/A
instance_id
1 minute
load_average5
(Agent) 5-Minute Load Average
CPU load averaged from the last 5 minutes
Linux: Obtain the metric value from the number of logic CPUs in load5/ in file /proc/loadavg. Run the top command and check the load5 value.
≥0
N/A
N/A
instance_id
1 minute
load_average15
(Agent) 15-Minute Load Average
CPU load averaged from the last 15 minutes
Linux: Obtain the metric value from the number of logic CPUs in load15/ in file /proc/loadavg. Run the top command and check the load15 value.
≥0
N/A
N/A
instance_id
1 minute
OS Metrics: Memory
Table 3 Memory metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
mem_available
(Agent) Available Memory
Available memory of the monitored object
  • Linux: Obtain the metric value from /proc/meminfo.
    • If MemAvailable is displayed in /proc/meminfo, obtain the value.
    • If MemAvailable is not displayed in /proc/meminfo, calculate the value with the formula MemAvailable = MemFree + Buffers + Cached.
  • Windows: Available memory = Total memory – Used memory. Obtain the metric value using the Windows API GlobalMemoryStatusEx.
≥0
GB
N/A
instance_id
1 minute
mem_usedPercent
(Agent) Memory Usage
Memory usage of the monitored object
  • Linux: Obtain the metric value from the /proc/meminfo file. Memory Usage = (MemTotal – MemAvailable)/MemTotal
    • If MemAvailable is displayed in /proc/meminfo, calculate the value with the formula MemUsedPercent = (MemTotal – MemAvailable)/MemTotal.
    • If MemAvailable is not displayed in /proc/meminfo, calculate the value with the formula MemUsedPercent = (MemTotal – MemFree – Buffers – Cached)/MemTotal.
  • Windows: Memory Usage = Used memory/Total memory x 100%
0-100
N/A
instance_id
1 minute
mem_free
(Agent) Idle Memory
Memory that is not being used
≥0
GB
N/A
instance_id
1 minute
mem_buffers
(Agent) Buffer
Memory that is being used for buffers
  • Linux: Obtain the metric value from /proc/meminfo. Run the top command and check the KiB Mem:buffers value.
≥0
GB
N/A
instance_id
1 minute
mem_cached
(Agent) Cache
Memory that is being used for caches
  • Linux: Obtain the metric value from /proc/meminfo. Run the top command and check the KiB Swap:cached Mem value.
≥0
GB
N/A
instance_id
1 minute
total_open_files
(Agent) Total File Handles
Total handles used by all processes
  • Linux: Use the /proc/{pid}/fd file to summarize the handles used by all processes.
≥0
Count
N/A
instance_id
1 minute
OS Metrics: Disk
  • Currently, Cloud Eye Agent only monitors physical disks. NFS-mounted disks cannot be monitored.
  • By default, Cloud Eye Agent excludes Docker-related mount points. The mount point prefixes are as follows:
    /var/lib/docker;/mnt/paas/kubernetes;/var/lib/mesos
Table 4 Disk metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
disk_free
(Agent) Available Disk Space
Available disk space of the monitored object
  • Linux: Run the df -h command and check the value in the Avail column. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
  • Windows: Obtain the metric value using the WMI API GetDiskFreeSpaceExW. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
≥0
GB
N/A
1 minute
disk_total
(Agent) Disk Storage Capacity
Total disk capacity of the monitored object
  • Linux: Run the df -h command and check the value in the Size column.
≥0
GB
N/A
1 minute
disk_used
(Agent) Used Disk Space
Used disk space of the monitored object
  • Linux: Run the df -h command and check the value in the Used column. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
≥0
GB
N/A
1 minute
disk_usedPercent
(Agent) Disk Usage
Disk usage of the monitored object
Formula: Disk Usage = Used Disk Space/Disk Storage Capacity
  • Linux: Obtain the metric value using the following formula: Disk Usage = Used Disk Space/Disk Storage Capacity. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
0-100
N/A
1 minute
OS Metrics: Disk I/O
Table 5 Disk I/O metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
disk_agt_read_bytes_rate
(Agent) Disks Read Rate
Number of bytes read from the monitored disk per second
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the sixth column in a collection period.
    • The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
  • Windows:
    • Obtain the metric value using the WMI object Win32_PerfFormattedData_PerfDisk_LogicalDisk.
    • High CPU usage may lead to timeouts in monitoring data collection.
≥ 0
byte/s
1024(IEC)
  • instance_id,mount_point
  • instance_id,disk
1 minute
disk_agt_read_requests_rate
(Agent) Disks Read Requests
Number of requests to read data from the monitored disk per second
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the fourth column in a collection period.
  • Windows:
≥ 0
request/s
N/A
  • instance_id,disk
1 minute
disk_agt_write_bytes_rate
(Agent) Disks Write Rate
Number of bytes written into the monitored disk per second
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the tenth column in a collection period.
  • Windows:
≥ 0
byte/s
1024(IEC)
  • instance_id,disk
1 minute
disk_agt_write_requests_rate
(Agent) Disks Write Requests
Number of requests to write data into the monitored disk per second
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the eighth column in a collection period.
  • Windows:
≥ 0
request/s
N/A
  • instance_id,disk
1 minute
disk_readTime
(Agent) Average Read Request Time
Average amount of time that read requests have waited on the disks
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the seventh column in a collection period.
≥ 0
ms/count
N/A
  • instance_id,disk
1 minute
disk_writeTime
(Agent) Average Write Request Time
Average amount of time that write requests have waited on the disks
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the eleventh column in a collection period.
≥ 0
ms/count
N/A
  • instance_id,disk
1 minute
disk_ioUtils
(Agent) Disk I/O Usage
Disk I/O usage of the monitored object
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the thirteenth column in a collection period.
0-100
N/A
  • instance_id,disk
1 minute
disk_queue_length
(Agent) Disk Queue Length
Average number of read or write requests waiting to be processed by the monitored disk in a monitoring period
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value based on data changes in the fourteenth column in a collection period.
≥ 0
Count
N/A
  • instance_id,disk
1 minute
disk_write_bytes_per_operation
(Agent) Average Disk Write Size
Average number of bytes written into the monitored disk per write I/O in a monitoring period
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value by dividing data changes in the tenth column by that in the eighth column in a collection period.
≥ 0
Byte/op
N/A
  • instance_id,disk
1 minute
disk_read_bytes_per_operation
(Agent) Average Disk Read Size
Average number of bytes read from the monitored disk per read I/O in a monitoring period
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value by dividing data changes in the sixth column by that in the fourth column in a collection period.
≥ 0
Byte/op
N/A
  • instance_id,disk
1 minute
disk_io_svctm
(Agent) Disk I/O Service Time
Average time the monitored disk takes to complete an I/O request (read or write) in a monitoring period
  • Linux:
    • In file /proc/diskstats, locate the device and calculate the metric value by dividing the data changes in the thirteenth column by the sum of data changes in the fourth and eighth columns in a collection period.
≥ 0
ms/op
N/A
  • instance_id,disk
1 minute
disk_device_used_percent
(Agent) Block Device Usage
Physical disk usage of the monitored object
Formula: Block device usage = Storage space used by all mounted disk partitions/Total disk storage space
  • Linux: Calculate the sum of storage space used by all mount points. Calculate the total disk storage space based on the disk sector size and the number of sectors. Then, calculate the block device usage based on the formula mentioned above.
0-100
N/A
  • instance_id,disk
1 minute
OS Metrics: File System
Table 6 File system metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
disk_fs_rwstate
(Agent) File System Read/Write Status
File system read/write status of the monitored object Possible values are 0 (read and write) and 1 (read-only).
  • Linux: Obtain the file system status from the fourth column in the /proc/mounts file.
  • 0: read and write
  • 1: read-only
N/A
N/A
1 minute
disk_inodesTotal
(Agent) Disk inode Total
Total number of index nodes on the disk
  • Linux: Run the df -i command and check the value in the Inodes column. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
≥ 0
N/A
N/A
1 minute
disk_inodesUsed
(Agent) Total inode Used
Number of used index nodes on the disk
  • Linux: Run the df -i command and check the value in the IUsed column. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
≥ 0
N/A
N/A
1 minute
disk_inodesUsedPercent
(Agent) Percentage of Total inode Used
Percentage of used index nodes on the disk
  • Linux: Run the df -i command and check the value in the IUse% column. The mount point prefix cannot exceed 64 characters. It must start with a letter and contain only digits, letters, hyphens (-), periods (.), and swung dashes (~).
0-100
N/A
1 minute
OS Metrics: TCP
Table 7 TCP metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
net_tcp_total
(Agent) Total TCP Connections
Total number of TCP connections in all states
  • Linux: Obtain TCP connections in all states from the /proc/net/tcp file, and then collect the number of connections in each state.
  • Windows: Obtain the metric value using the Windows API GetTcpTable2.
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_established
(Agent) TCP ESTABLISHED Connections
Number of TCP connections in ESTABLISHED state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_sys_sent
(Agent) TCP SYS_SENT Connections
Number of TCP connections that are being requested by the client
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_sys_recv
(Agent) TCP SYS_RECV Connections
Number of pending TCP connections received by the server
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_fin_wait1
(Agent) TCP FIN_WAIT1 Connections
Number of TCP connections waiting for ACK packets when the connections are being actively closed by the client
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_fin_wait2
(Agent) TCP FIN_WAIT2 Connections
Number of TCP connections in FIN_WAIT2 state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_time_wait
(Agent) TCP TIME_WAIT Connections
Number of TCP connections in TIME_WAIT state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_close
(Agent) TCP CLOSE Connections
Number of closed TCP connections
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_close_wait
(Agent) TCP CLOSE_WAIT Connections
Number of TCP connections in CLOSE_WAIT TCP state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_last_ack
(Agent) TCP LAST_ACK Connections
Number of TCP connections waiting for ACK packets when the connections are being passively closed by the client
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_listen
(Agent) TCP LISTEN Connections
Number of TCP connections in LISTEN state
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_closing
(Agent) TCP CLOSING Connections
Number of TCP connections to be actively closed by the server and the client at the same time
≥ 0
Count
N/A
instance_id
1 minute
net_tcp_retrans
(Agent) TCP Retransmission Rate
Percentage of packets that are resent
  • Linux: Obtain the metric value from the /proc/net/snmp file. The value is the ratio of the number of retransmitted packets to the number of total packets sent in a collection period.
  • Windows: Obtain the metric value using the Windows API GetTcpStatistics.
0-100
N/A
instance_id
1 minute
OS Metrics: NIC
Table 8 NIC metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
net_bitRecv
(Agent) Outbound Bandwidth
Number of bits sent by the monitored object per second
  • Linux: Check metric value changes in file /proc/net/dev in a collection period.
  • Windows: Obtain the metric value using the WMI object MibIfRow.
≥ 0
bit/s
1024(IEC)
  • instance_id
  • instance_id,network_interface_card
1 minute
net_bitSent
(Agent) Inbound Bandwidth
Number of bits received by the monitored object per second
≥ 0
bit/s
1024(IEC)
  • instance_id
1 minute
net_packetRecv
(Agent) NIC Packet Receive Rate
Number of packets received by the monitored object per second
≥ 0
Count/s
N/A
  • instance_id
1 minute
net_packetSent
(Agent) NIC Packet Send Rate
Number of packets sent by the monitored object per second
≥ 0
Count/s
N/A
  • instance_id
1 minute
net_errin
(Agent) Receive Error Rate
Percentage of error packets relative to the total packets received by the monitored object per second
0-100
N/A
  • instance_id
1 minute
net_errout
(Agent) Transmit Error Rate
Percentage of error packets relative to the total packets sent by the monitored object per second
0-100
N/A
  • instance_id
1 minute
net_dropin
(Agent) Received Packet Drop Rate
Percentage of received but dropped packets relative to the total packets received by the monitored object per second
0-100
N/A
  • instance_id
1 minute
net_dropout
(Agent) Transmitted Packet Drop Rate
Percentage of sent but dropped packets relative to the total packets sent by the monitored object per second
0-100
N/A
  • instance_id
1 minute
Process Monitoring Metrics
Table 9 Process Metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
proc_pHashId_cpu
(Agent) CPU Usage
CPU consumed by a process. pHashId is the MD5 value of the process name plus process ID.
  • Linux: Check metric value changes in file /proc/pid/stat.
  • Windows: Obtain the metric value using the Windows API GetProcessTimes.
0–1 x Number of CPU cores
N/A
instance_id
1 minute
proc_pHashId_mem
Memory consumed by a process. pHashId is the MD5 value of the process name plus process ID.
  • Linux:
    RSS*PAGESIZE/MemTotal
    Obtain the RSS value by checking the second column of the file /proc/pid/statm.
    Obtain the PAGESIZE value by running the getconf PAGESIZE command.
    Obtain the MemTotal value by checking the file /proc/meminfo.
  • Windows: Call the Windows API procGlobalMemoryStatusEx to obtain the total memory size. Call GetProcessMemoryInfo to obtain the used memory size. Divide the total size by the used size to get the memory usage.
0-100
N/A
instance_id
1 minute
proc_pHashId_file
(Agent) Opened Files
Number of files opened by a process. pHashId is the MD5 value of the process name plus process ID.
  • Linux: Run the ls -l /proc/pid/fd command to check the number of opened files.
≥0
Count
N/A
instance_id
1 minute
proc_running_count
(Agent) Running Processes
Number of running processes of the monitored object
  • Linux: Obtain the state of each process by checking the Status value in the /proc/pid/status file, and then collect the total number of processes in each state.
≥0
Count
N/A
instance_id
1 minute
proc_idle_count
(Agent) Idle Processes
Number of idle processes of the monitored object
≥0
Count
N/A
instance_id
1 minute
proc_zombie_count
(Agent) Zombie Processes
Number of zombie processes of the monitored object
≥0
Count
N/A
instance_id
1 minute
proc_blocked_count
(Agent) Blocked Processes
Number of blocked processes of the monitored object
≥0
Count
N/A
instance_id
1 minute
proc_sleeping_count
(Agent) Sleeping Processes
Number of sleeping processes of the monitored object
≥0
Count
N/A
instance_id
1 minute
proc_total_count
(Agent) Total Processes
Total number of processes of the monitored object
  • Windows: Obtain the metric value using psapi.dll, the Windows process status API library.
≥0
Count
N/A
instance_id
1 minute
proc_specified_count
(Agent) Specified Processes
Number of specified processes
≥0
N/A
N/A
instance_id,proc
1 minute
OS Metrics: GPU
If a GPU server has eight GPUs and the PM mode is disabled, data may fail to be collected. You can enable the PM mode and restart the monitoring process to fix it.
Table 10 GPU metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
gpu_status
(Agent) GPU Health Status
GPU health status. It is a composite metric.
Possible causes: 1. The ECC exceeds the threshold. 2. The GPU memory address failed to be remapped. 3. GPU shows rev ff error. 4. infoROM error occurs. 5. There are pages to be isolated. 6. remapped rows error occurs. For details, see the detailed metrics below.
  • Linux: Obtain the metric value by calling the API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the API provided by the GPU driver library nvml.dll.
  • 0: healthy
  • 1: subhealthy
  • 2: faulty
N/A
N/A
instance_id,gpu
1 minute
gpu_performance_state
(Agent) Performance Status
GPU performance status
  • Linux: Obtain the metric value by calling the NvmlDeviceGetPerformanceState API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetPerformanceState API provided by the GPU driver library nvml.dll.
P0–P15, P32
  • P0: the maximum performance
  • P15: the minimum performance
  • P32: unknown performance status
N/A
N/A
instance_id,gpu
1 minute
gpu_power_draw
(Agent) GPU Draw Power
Draw power on the GPU. If the power exceeds the maximum or is an incorrect value, the GPU hardware may be faulty.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetPowerUsage API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetPowerUsage API provided by the GPU driver library nvml.dll.
≥ 0
W
N/A
instance_id,gpu
1 minute
gpu_temperature
(Agent) GPU Temperature
Temperature of the GPU. If the temperature exceeds the threshold or is an incorrect value, the GPU hardware may be faulty.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetTemperature API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetTemperature API provided by the GPU driver library nvml.dll.
≥ 0
°C
N/A
instance_id,gpu
1 minute
gpu_usage_gpu
(Agent) GPU Usage
GPU compute usage. It is an instantaneous value at a sampling point.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetUtilizationRates API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetUtilizationRates API provided by the GPU driver library nvml.dll.
0-100
N/A
instance_id,gpu
1 minute
gpu_usage_mem
(Agent) GPU Memory Usage
GPU memory usage. It is an instantaneous value at a sampling point.
0-100
N/A
  • instance_id,gpu
  • instance_id,gpu_slot,pid_for_gpu
1 minute
gpu_used_mem
(Agent) GPU Used Memory
Memory used on the GPU
  • Linux: Obtain the metric value by calling the NvmlDeviceGetMemoryInfo API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetMemoryInfo API provided by the GPU driver library nvml.dll.
≥ 0
MB
N/A
  • instance_id,gpu
1 minute
gpu_free_mem
(Agent) Remaining GPU Memory
Idle GPU memory
≥ 0
MB
N/A
instance_id,gpu
1 minute
gpu_usage_encoder
(Agent) Encoding Usage
Encoder usage of the GPU. It is an instantaneous value at a sampling point.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetEncoderUtilization API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetEncoderUtilization API provided by the GPU driver library nvml.dll.
0-100
N/A
  • instance_id,gpu
1 minute
gpu_usage_decoder
(Agent) Decoding Usage
Decoder usage of the GPU. It is an instantaneous value at a sampling point.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetDecoderUtilization API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetDecoderUtilization API provided by the GPU driver library nvml.dll.
0-100
N/A
  • instance_id,gpu
1 minute
gpu_graphics_clocks
(Agent) GPU Graphics Clocks
GPU graphics (shader) clock frequency. The value is the GPU clock frequency related to graphics performance. If graphics capabilities are used, you can ignore this metric.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetClockInfo API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetClockInfo API provided by the GPU driver library nvml.dll.
≥ 0
MHz
N/A
instance_id,gpu
1 minute
gpu_sm_clocks
(Agent) GPU SM Clocks
SM clocks on the GPU. The value is the clock frequency for controlling the GPU memory speed.
≥ 0
MHz
N/A
instance_id,gpu
1 minute
gpu_mem_clock
(Agent) GPU Memory Clocks
Memory clocks on the GPU. The value is the clock frequency closely related to CUDA core computing of the GPU.
≥ 0
MHz
N/A
instance_id,gpu
1 minute
gpu_video_clocks
(Agent) GPU Video Clocks
Video clocks on the GPU. The value is the codec clock frequency of the GPU.
≥ 0
MHz
N/A
instance_id,gpu
1 minute
gpu_tx_throughput_pci
(Agent) GPU PCI Tx Throughput
PCI Tx throughput on the GPU. The value is the amount of data sent by the GPU to the host via PCIe.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetPcieThroughput API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetPcieThroughput API provided by the GPU driver library nvml.dll.
≥ 0
MByte/s
N/A
instance_id,gpu
1 minute
gpu_rx_throughput_pci
(Agent) GPU PCI Rx Throughput
PCI Rx throughput on the GPU. The value is the amount of data sent by the host to the GPU via PCIe.
≥ 0
MByte/s
N/A
instance_id,gpu
1 minute
gpu_volatile_correctable
(Agent) Volatile Correctable ECC Errors
Number of correctable ECC errors since the GPU is reset. The value is reset to 0 each time the GPU is reset.
≥ 0
Count
N/A
instance_id,gpu
1 minute
gpu_volatile_uncorrectable
(Agent) Volatile Uncorrectable ECC Errors
Number of uncorrectable ECC errors since the GPU is reset. The value is reset to 0 each time the GPU is reset.
  • Linux: Obtain the metric value by calling the NvmlDeviceGetTotalEccErrors or NvmlDeviceGetMemoryErrorCounter API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetTotalEccErrors or NvmlDeviceGetMemoryErrorCounter API provided by the GPU driver library nvml.dll.
≥ 0
Count
N/A
instance_id,gpu
1 minute
gpu_aggregate_correctable
(Agent) Aggregate Correctable ECC Errors
Aggregate correctable ECC errors on the GPU
≥ 0
Count
N/A
instance_id,gpu
1 minute
gpu_aggregate_uncorrectable
(Agent) Aggregate Uncorrectable ECC Errors
Aggregate uncorrectable ECC errors on the GPU
≥ 0
Count
N/A
instance_id,gpu
1 minute
gpu_retired_page_single_bit
(Agent) Retired Page Single Bit Errors
Number of retired page single bit errors, which indicates the number of single-bit error pages blocked by the GPU
  • Linux: Obtain the metric value by calling the NvmlDeviceGetRetiredPages API provided by the GPU driver library libnvidia-ml.so.1.
  • Windows: Obtain the metric value by calling the NvmlDeviceGetRetiredPages API provided by the GPU driver library nvml.dll.
≥ 0
Count
N/A
instance_id,gpu
1 minute
gpu_retired_page_double_bit
(Agent) Retired Page Double Bit Errors
Number of retired page double bit errors, which indicates the number of double-bit error pages blocked by the GPU
≥ 0
Count
N/A
instance_id,gpu
1 minute
gpu_lnkcap_speed
(Agent) Max. GPU Link Speed
Maximum PCIe link speed of the GPU, which means the maximum data throughput of the GPU on the PCIe bus
  • Linux: Obtain the metric value by running lspci -d 10de: -vv | grep -i lnkcap.
  • Windows: Obtain the metric value by running (gwmi Win32_Bus -Filter 'DeviceID like "PCI%"').GetRelated('Win32_PnPEntity').
≥ 0
GT/s
N/A
instance_id,gpu
1 minute
gpu_lnkcap_width
(Agent) Max. GPU Link Width
Maximum PCIe link width of the GPU, which means the maximum number of PCIe lanes supported by the GPU
≥ 0
count
N/A
instance_id,gpu
1 minute
gpu_lnksta_speed
(Agent) GPU Link Speed
  • Linux: Obtain the metric value by running lspci -d 10de: -vv | grep -i lnksta.
≥ 0
GT/s
N/A
instance_id,gpu
1 minute
gpu_lnksta_width
(Agent) GPU Link Width
PCIe link width of the GPU, which means the number of PCIe lanes of the GPU
≥ 0
count
N/A
instance_id,gpu
1 minute
gpu_nvlink_number
(Agent) GPU NVLinks
Number of NVLinks of the GPU. For example, A100 supports 12 NVLinks.
  • Linux: Obtain the metric value by calling the nvmlDeviceGetFieldValue API provided by the GPU driver library libnvidia-ml.so.1.
≥ 0
count
N/A
instance_id,gpu
1 minute
gpu_nvlink_bandwidth
(Agent) Average GPU NVLink Bandwidth
Average NVLink bandwidth of the GPU
The value is the total bandwidth for GPU data transmission.
≥ 0
GB/s
N/A
instance_id,gpu
1 minute
OS Metrics: NPU
Table 11 NPU metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
npu_device_health
(Agent) NPU Device Health
NPU health status
  • 0: healthy
  • 1: minor alarm
  • 2: major alarm
  • 3: critical alarm
N/A
N/A
instance_id,npu
1 minute
npu_driver_health
(Agent) NPU Driver Health
Health status of the NPU driver
  • 0: healthy
  • 1: minor alarm
  • 2: major alarm
  • 3: critical alarm
N/A
N/A
instance_id,npu
1 minute
npu_power
(Agent) NPU Power
NPU power
>0
W
N/A
instance_id,npu
1 minute
npu_temperature
(Agent) NPU Temperature
NPU temperature
Natural numbers
°C
N/A
instance_id,npu
1 minute
npu_voltage
(Agent) NPU Voltage
NPU voltage
Natural numbers
V
N/A
instance_id,npu
1 minute
npu_util_rate_hbm
(Agent) NPU HBM Usage
NPU HBM usage
0-100
N/A
instance_id,npu
1 minute
npu_hbm_freq
(Agent) NPU HBM Frequency
NPU HBM frequency
>0
MHz
N/A
instance_id,npu
1 minute
npu_freq_hbm
NPU HBM frequency
>0
MHz
N/A
instance_id,npu
1 minute
npu_hbm_usage
(Agent) Used HBM
Used NPU HBM
≥0
MB
N/A
instance_id,npu
1 minute
npu_hbm_temperature
(Agent) HBM Temperature
NPU HBM temperature
Natural numbers
°C
N/A
instance_id,npu
1 minute
npu_hbm_bandwidth_util
(Agent) HBM Bandwidth Usage
NPU HBM bandwidth usage
0-100
N/A
instance_id,npu
1 minute
npu_hbm_mem_capacity
(Agent) HBM Memory Capacity
NPU HBM memory capacity
≥0
MB
N/A
instance_id,npu
1 minute
npu_hbm_ecc_enable
(Agent) HBM ECC Check Status
Whether HBM ECC check is enabled for the NPU
  • 0: disabled
  • 1: enabled
N/A
N/A
instance_id,npu
1 minute
npu_hbm_single_bit_error_cnt
(Agent) HBM Single-Bit Errors
Number of HBM single-bit errors of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_hbm_double_bit_error_cnt
(Agent) HBM Double-Bit Errors
Number of HBM double-bit errors of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_hbm_total_single_bit_error_cnt
(Agent) Single-Bit Errors in HBM Lifecycle
Number of single-bit errors in an NPU HBM lifecycle
≥0
count
N/A
instance_id,npu
1 minute
npu_hbm_total_double_bit_error_cnt
(Agent) Double-Bit Errors in HBM Lifecycle
Number of double-bit errors in an NPU HBM lifecycle
≥0
count
N/A
instance_id,npu
1 minute
npu_hbm_single_bit_isolated_pages_cnt
(Agent) Isolated Memory Pages with HBM Single-Bit Errors
Number of isolated memory pages with single-bit HBM errors of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_hbm_double_bit_isolated_pages_cnt
(Agent) Isolated Memory Pages with HBM Double-Bit Errors
Number of isolated memory pages with double-bit HBM errors of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_usage_mem
(Agent) Used NPU Memory
Memory used on the NPU
≥0
MB
N/A
instance_id,npu
1 minute
npu_util_rate_mem
(Agent) NPU Memory Usage
NPU memory usage
0-100
N/A
instance_id,npu
1 minute
npu_util_rate_hbm_bw
(Agent) NPU HBM Bandwidth Usage
0-100
N/A
instance_id,npu
1 minute
npu_freq_mem
(Agent) NPU Memory Frequency
NPU memory frequency
>0
MHz
N/A
instance_id,npu
1 minute
npu_util_rate_mem_bandwidth
(Agent) NPU Memory Bandwidth Usage
NPU memory bandwidth usage
0-100
N/A
instance_id,npu
1 minute
npu_util_rate_vector_core
(Agent) NPU Vector Core Usage
Vector core usage of the NPU
0-100
N/A
instance_id,npu
1 minute
npu_sbe
(Agent) NPU Single-Bit Errors
Number of single-bit errors on the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_dbe
(Agent) NPU Double-Bit Errors
Number of dual-bit errors on the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_freq_ai_core
(Agent) NPU AI Core Frequency
AI core clock frequency of the NPU
>0
MHz
N/A
instance_id,npu
1 minute
npu_freq_ai_core_rated
(Agent) Rated NPU AI Core Frequency
Rated AI core frequency of the NPU
>0
MHz
N/A
instance_id,npu
1 minute
npu_util_rate_ai_core
(Agent) NPU AI Core Usage
AI core usage of the NPU
0-100
N/A
instance_id,npu
1 minute
npu_aicpu_num
(Agent) NPU AI CPUs
Number of AI CPUs on the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_util_rate_ai_cpu
(Agent) NPU AI CPU Usage
AI CPU usage of the NPU
0-100
N/A
instance_id,npu
1 minute
npu_aicpu_avg_util_rate
(Agent) Average AI CPU Usage of NPU
Average AI CPU usage of the NPU
0-100
N/A
instance_id,npu
1 minute
npu_aicpu_max_freq
(Agent) Max. AI CPU Frequency of NPU
Maximum AI CPU frequency of the NPU
>0
MHz
N/A
instance_id,npu
1 minute
npu_aicpu_cur_freq
(Agent) AI CPU Frequency of NPU
>0
MHz
N/A
instance_id,npu
1 minute
npu_util_rate_ctrl_cpu
(Agent) NPU Control CPU Usage
CPU usage controlled by the NPU
0-100
N/A
instance_id,npu
1 minute
npu_freq_ctrl_cpu
(Agent) NPU Control CPU Frequency
CPU frequency controlled by the NPU
>0
MHz
N/A
instance_id,npu
1 minute
npu_link_cap_speed
(Agent) Max. NPU Link Speed
Maximum link speed of the NPU
≥0
GT/s
N/A
instance_id,npu
1 minute
npu_link_cap_width
(Agent) Max. NPU Link Width
Maximum link width of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_link_status_speed
(Agent) NPU Link Speed
Link speed of the NPU
≥0
GT/s
N/A
instance_id,npu
1 minute
npu_link_status_width
(Agent) NPU Link Width
Link width of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_device_network_health
(Agent) NPU Network Health
RoCE IP address connectivity of the NPU
  • 0: The network is healthy.
  • Other values: The network status is unhealthy.
N/A
N/A
instance_id,npu
1 minute
npu_network_port_link_status
(Agent) NPU Network Port Link Status
Link status of the network port on the NPU
  • 0: up
  • 1: down
N/A
N/A
instance_id,npu
1 minute
npu_roce_tx_rate
(Agent) NPU NIC Uplink Rate
NIC uplink rate of the NPU
≥0
MB/s
N/A
instance_id,npu
1 minute
npu_roce_rx_rate
(Agent) NPU NIC Downlink Rate
NIC downlink rate of the NPU
≥0
MB/s
N/A
instance_id,npu
1 minute
npu_mac_tx_mac_pause_num
(Agent) Pause Frames Sent by MAC
Total number of pause frames sent by the MAC address of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_mac_rx_mac_pause_num
(Agent) Pause Frames Received by MAC
Total number of pause frames received by the MAC address of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_mac_tx_pfc_pkt_num
(Agent) PFC Frames Sent by MAC
Total number of PFC frames sent by the MAC address of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_mac_rx_pfc_pkt_num
(Agent) PFC Frames Received by MAC
Total number of PFC frames received by the MAC address of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_mac_tx_bad_pkt_num
(Agent) Bad Packets Sent by MAC
Total number of bad packets sent by the MAC address of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_mac_rx_bad_pkt_num
(Agent) Bad Packets Received by MAC
Total number of bad packets received by the MAC address of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_tx_err_pkt_num
(Agent) Bad Packets Sent by RoCE
Total number of bad packets sent by the RoCE NIC of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_rx_err_pkt_num
(Agent) Bad Packets Received by RoCE
Total number of bad packets received by the RoCE NIC of the NPU
≥0
count
N/A
instance_id,npu
1 minute
npu_opt_temperature
(Agent) NPU Optical Module Case Temperature
Case temperature of the NPU optical module
Natural numbers
°C
N/A
instance_id,npu
1 minute
npu_opt_temperature_high_thres
(Agent) Max. NPU Optical Module Case Temperature
Upper limit for the case temperature of the NPU optical module
Natural numbers
°C
N/A
instance_id,npu
1 minute
npu_opt_temperature_low_thres
(Agent) Min. NPU Optical Module Case Temperature
Lower limit for the case temperature of the NPU optical module
Natural numbers
°C
N/A
instance_id,npu
1 minute
npu_opt_voltage
(Agent) NPU Optical Module Voltage
Voltage of the NPU optical module
Natural numbers
mV
N/A
instance_id,npu
1 minute
npu_opt_voltage_high_thres
(Agent) Max. NPU Optical Module Voltage
Upper limit for the voltage of the NPU optical module
Natural numbers
mV
N/A
instance_id,npu
1 minute
npu_opt_voltage_low_thres
(Agent) Min. NPU Optical Module Voltage
Lower limit for the voltage of the NPU optical module
Natural numbers
mV
N/A
instance_id,npu
1 minute
npu_opt_tx_power_lane0
(Agent) NPU Optical Module Lane 0 TX Power
Transmit power of NPU optical module lane 0
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_tx_power_lane1
(Agent) NPU Optical Module Lane 1 TX Power
Transmit power of NPU optical module lane 1
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_tx_power_lane2
(Agent) NPU Optical Module Lane 2 TX Power
Transmit power of NPU optical module lane 2
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_tx_power_lane3
(Agent) NPU Optical Module Lane 3 TX Power
Transmit power of NPU optical module lane 3
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_rx_power_lane0
(Agent) NPU Optical Module Lane 0 RX Power
Receive power of NPU optical module lane 0
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_rx_power_lane1
(Agent) NPU Optical Module Lane 1 RX Power
Receive power of NPU optical module lane 1
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_rx_power_lane2
(Agent) NPU Optical Module Lane 2 RX Power
Receive power of NPU optical module lane 2
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_rx_power_lane3
(Agent) NPU Optical Module Lane 3 RX Power
Receive power of NPU optical module lane 3
≥0
mW
N/A
instance_id,npu
1 minute
npu_opt_tx_bias_lane0
(Agent) NPU Optical Module Lane 0 TX Bias Current
Transmit bias current of NPU optical module lane 0
≥0
mA
N/A
instance_id,npu
1 minute
npu_opt_tx_bias_lane1
(Agent) NPU Optical Module Lane 1 TX Bias Current
Transmit bias current of NPU optical module lane 1
≥0
mA
N/A
instance_id,npu
1 minute
npu_opt_tx_bias_lane2
(Agent) NPU Optical Module Lane 2 TX Bias Current
Transmit bias current of NPU optical module lane 2
≥0
mA
N/A
instance_id,npu
1 minute
npu_opt_tx_bias_lane3
(Agent) NPU Optical Module Lane 3 TX Bias Current
Transmit bias current of NPU optical module lane 3
≥0
mA
N/A
instance_id,npu
1 minute
npu_opt_tx_los
(Agent) NPU Optical Module TX LOS
Statistics on Transmit LOS Flag of the NPU optical module
≥0
count
N/A
instance_id,npu
1 minute
npu_opt_rx_los
(Agent) NPU Optical Module RX LOS
Statistics on Receive LOS Flag of the NPU optical module
≥0
count
N/A
instance_id,npu
1 minute
npu_macro1_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro1 0lane
Maximum duration of NPU Macro1 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro1_0lane_total_sec
(Agent) Total Duration of NPU Macro1 0lane
Total duration of NPU Macro1 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro1_crc_error_cnt
(Agent) Error Packets Received by NPU Macro1
Number of CRC error packets received by NPU Macro1 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro1_crc_error_rate
(Agent) NPU Macro1 BER
Percentage of CRC error packets received by NPU Macro1 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro1_retry_cnt
(Agent) Packets Retransmitted by NPU Macro1
Number of packets retransmitted by NPU Macro1 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro1_rx_cnt
(Agent) Packets Received by NPU Macro1
Number of packets received by NPU Macro1 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro1_serdes_lane0_snr
(Agent) NPU Macro1 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro1 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro1_serdes_lane1_snr
(Agent) NPU Macro1 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro1 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro1_serdes_lane2_snr
(Agent) NPU Macro1 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro1 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro1_serdes_lane3_snr
(Agent) NPU Macro1 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro1 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro1_tx_cnt
(Agent) Packets Sent by NPU Macro1
Number of packets sent by NPU Macro1 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro2_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro2 0lane
Maximum duration of NPU Macro2 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro2_0lane_total_sec
(Agent) Total Duration of NPU Macro2 0lane
Total duration of NPU Macro2 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro2_crc_error_cnt
(Agent) Error Packets Received by NPU Macro2
Number of CRC error packets received by NPU Macro2 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro2_crc_error_rate
(Agent) NPU Macro2 BER
Percentage of CRC error packets received by NPU Macro2 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro2_retry_cnt
(Agent) Packets Retransmitted by NPU Macro2
Number of packets retransmitted by NPU Macro2 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro2_rx_cnt
(Agent) Packets Received by NPU Macro2
Number of packets received by NPU Macro2 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro2_serdes_lane0_snr
(Agent) NPU Macro2 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro2 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro2_serdes_lane1_snr
(Agent) NPU Macro2 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro2 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro2_serdes_lane2_snr
(Agent) NPU Macro2 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro2 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro2_serdes_lane3_snr
(Agent) NPU Macro2 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro2 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro2_tx_cnt
(Agent) Packets Sent by NPU Macro2
Number of packets sent by NPU Macro2 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro3_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro3 0lane
Maximum duration of NPU Macro3 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro3_0lane_total_sec
(Agent) Total Duration of NPU Macro3 0lane
Total duration of NPU Macro3 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro3_crc_error_cnt
(Agent) Error Packets Received by NPU Macro3
Number of CRC error packets received by NPU Macro3 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro3_crc_error_rate
(Agent) NPU Macro3 BER
Percentage of CRC error packets received by NPU Macro3 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro3_retry_cnt
(Agent) Packets Retransmitted by NPU Macro3
Number of packets retransmitted by NPU Macro3 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro3_rx_cnt
(Agent) Packets Received by NPU Macro3
Number of packets received by NPU Macro3 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro3_serdes_lane0_snr
(Agent) NPU Macro3 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro3 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro3_serdes_lane1_snr
(Agent) NPU Macro3 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro3 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro3_serdes_lane2_snr
(Agent) NPU Macro3 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro3 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro3_serdes_lane3_snr
(Agent) NPU Macro3 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro3 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro3_tx_cnt
(Agent) Packets Sent by NPU Macro3
Number of packets sent by NPU Macro3 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro4_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro4 0lane
Maximum duration of NPU Macro4 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro4_0lane_total_sec
(Agent) Total Duration of NPU Macro4 0lane
Total duration of NPU Macro4 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro4_crc_error_cnt
(Agent) Error Packets Received by NPU Macro4
Number of CRC error packets received by NPU Macro4 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro4_crc_error_rate
(Agent) NPU Macro4 BER
Percentage of CRC error packets received by NPU Macro4 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro4_retry_cnt
(Agent) Packets Retransmitted by NPU Macro4
Number of packets retransmitted by NPU Macro4 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro4_rx_cnt
(Agent) Packets Received by NPU Macro4
Number of packets received by NPU Macro4 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro4_serdes_lane0_snr
(Agent) NPU Macro4 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro4 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro4_serdes_lane1_snr
(Agent) NPU Macro4 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro4 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro4_serdes_lane2_snr
(Agent) NPU Macro4 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro4 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro4_serdes_lane3_snr
(Agent) NPU Macro4 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro4 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro4_tx_cnt
(Agent) Packets Sent by NPU Macro4
Number of packets sent by NPU Macro4 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro5_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro5 0lane
Maximum duration of NPU Macro5 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro5_0lane_total_sec
(Agent) Total Duration of NPU Macro5 0lane
Total duration of NPU Macro5 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro5_crc_error_cnt
(Agent) Error Packets Received by NPU Macro5
Number of CRC error packets received by NPU Macro5 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro5_crc_error_rate
(Agent) NPU Macro5 BER
Percentage of CRC error packets received by NPU Macro5 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro5_retry_cnt
(Agent) Packets Retransmitted by NPU Macro5
Number of packets retransmitted by NPU Macro5 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro5_rx_cnt
(Agent) Packets Received by NPU Macro5
Number of packets received by NPU Macro5 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro5_serdes_lane0_snr
(Agent) NPU Macro5 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro5 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro5_serdes_lane1_snr
(Agent) NPU Macro5 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro5 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro5_serdes_lane2_snr
(Agent) NPU Macro5 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro5 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro5_serdes_lane3_snr
(Agent) NPU Macro5 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro5 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro5_tx_cnt
(Agent) Packets Sent by NPU Macro5
Number of packets sent by NPU Macro5 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro6_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro6 0lane
Maximum duration of NPU Macro6 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro6_0lane_total_sec
(Agent) Total Duration of NPU Macro6 0lane
Total duration of NPU Macro6 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro6_crc_error_cnt
(Agent) Error Packets Received by NPU Macro6
Number of CRC error packets received by NPU Macro6 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro6_crc_error_rate
(Agent) NPU Macro6 BER
Percentage of CRC error packets received by NPU Macro6 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro6_retry_cnt
(Agent) Packets Retransmitted by NPU Macro6
Number of packets retransmitted by NPU Macro6 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro6_rx_cnt
(Agent) Packets Received by NPU Macro6
Number of packets received by NPU Macro6 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro6_serdes_lane0_snr
(Agent) NPU Macro6 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro6 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro6_serdes_lane1_snr
(Agent) NPU Macro6 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro6 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro6_serdes_lane2_snr
(Agent) NPU Macro6 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro6 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro6_serdes_lane3_snr
(Agent) NPU Macro6 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro6 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro6_tx_cnt
(Agent) Packets Sent by NPU Macro6
Number of packets sent by NPU Macro6 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro7_0lane_max_consec_sec
(Agent) Max. Duration of NPU Macro7 0lane
Maximum duration of NPU Macro7 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro7_0lane_total_sec
(Agent) Total Duration of NPU Macro7 0lane
Total duration of NPU Macro7 0lane in a monitoring period
≥0
s
N/A
instance_id,npu
1 minute
npu_macro7_crc_error_cnt
(Agent) Error Packets Received by NPU Macro7
Number of CRC error packets received by NPU Macro7 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro7_crc_error_rate
(Agent) NPU Macro7 BER
Percentage of CRC error packets received by NPU Macro7 in a monitoring period
0-100
N/A
instance_id,npu
1 minute
npu_macro7_retry_cnt
(Agent) Packets Retransmitted by NPU Macro7
Number of packets retransmitted by NPU Macro7 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro7_rx_cnt
(Agent) Packets Received by NPU Macro7
Number of packets received by NPU Macro7 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_macro7_serdes_lane0_snr
(Agent) NPU Macro7 SerDes Lane0 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro7 SerDes Lane0
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro7_serdes_lane1_snr
(Agent) NPU Macro7 SerDes Lane1 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro7 SerDes Lane1
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro7_serdes_lane2_snr
(Agent) NPU Macro7 SerDes Lane2 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro7 SerDes Lane2
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro7_serdes_lane3_snr
(Agent) NPU Macro7 SerDes Lane3 SNR
Signal-to-Noise Ratio (SNR) of NPU Macro7 SerDes Lane3
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_macro7_tx_cnt
(Agent) Packets Sent by NPU Macro7
Number of packets sent by NPU Macro7 in a monitoring period
≥0
count
N/A
instance_id,npu
1 minute
npu_opt_media_snr_lane0
(Agent) NPU Optical Module Lane 0 Optical SNR
Signal-to-Noise Ratio (SNR) on the media (optical) side of lane 0 in the NPU optical module
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_opt_media_snr_lane1
(Agent) NPU Optical Module Lane 1 Optical SNR
Signal-to-Noise Ratio (SNR) on the media (optical) side of lane 1 in the NPU optical module
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_opt_media_snr_lane2
(Agent) NPU Optical Module Lane 2 Optical SNR
Signal-to-Noise Ratio (SNR) on the media (optical) side of lane 2 in the NPU optical module
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_opt_media_snr_lane3
(Agent) NPU Optical Module Lane 3 Optical SNR
Signal-to-Noise Ratio (SNR) on the media (optical) side of lane 3 in the NPU optical module
Natural numbers
db
N/A
instance_id,npu
1 minute
npu_roce_new_pkt_rty_num
(Agent) Packets Retransmitted by NPU RoCE
Number of packets retransmitted by NPU RoCE
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_out_of_order_num
(Agent) PSN Error Packets Received by NPU RoCE
Number of NPU RoCE packets with a PSN greater than the expected one or duplicating with an existing one If packets are out of order or lost, retransmission will be triggered.
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_rx_all_pkt_num
(Agent) Packets Received by NPU RoCE
Total number of packets received by NPU RoCE
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_rx_cnp_pkt_num
(Agent) CNP Packets Received by NPU RoCE
Total number of CNP packets received by NPU RoCE
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_tx_all_pkt_num
(Agent) Packets Sent by NPU RoCE
Total number of packets sent by NPU RoCE
≥0
count
N/A
instance_id,npu
1 minute
npu_roce_tx_cnp_pkt_num
(Agent) CNP Packets Sent by NPU RoCE
Total number of CNP packets sent by NPU RoCE
≥0
count
N/A
instance_id,npu
1 minute
Total number of bad packets sent by the RoCE NIC of the NPU for reference
≥0
count
N/A
instance_id,npu
1 minute
If an object is in a hierarchical system, specify the monitored dimension in hierarchical form when you use APIs to query metrics of this object.
For example, to query the available space (metric: disk_free) of a disk mount point on a BMS, the dimension of the metric is instance_id,mount_point, where instance_id indicates level 0 and mount_point indicates level 1.
  • To query a single metric by calling an API, the mount_point dimension is used as follows:
    dim.0=instance_id,3d65c1ac-9a9f-4c5f-a054-35184a087bb2&dim.1=mount_point,6666cd76f96956469e7be39d750cc7d9
    3d65c1ac-9a9f-4c5f-a054-35184a087bb2 and 6666cd76f96956469e7be39d750cc7d9 are the values of instance_id and mount_point, respectively. For details about how to obtain the values, see Dimensions.
  • To query multiple metrics by calling an API, the mount_point dimension is used as follows:
    "dimensions": [
                         "name": "instance_id",
                         "value": "3d65c1ac-9a9f-4c5f-a054-35184a087bb2"
                         "name": "mount_point",
                         "value": "6666cd76f96956469e7be39d750cc7d9"
Dimensions
Dimension
Key
Value
Cloud server
instance_id
Cloud server
Server process
proc
Process
Cloud server disk
disk
Disk
Cloud server mount point
mount_point
Mount point
Cloud server GPU
gpu
GPU
Cloud server NPU
npu
NPU
Cloud server NIC
NIC
Cloud server GPU
gpu_slot
GPU
GPU process ID of cloud server
pid_for_gpu
GPU process ID
