Updated on 2025-11-20 GMT+08:00
Setting Menus of an Application
In development, sandbox, or runtime environments, you can customize the menus of a low-code application. These changes only apply to the current application and do not affect the original application package settings. For details about how to change the original settings in the application package, see Customizing Applications. This section explains how to set up a menu of an application, including adding one or more tabs.
Configuring the Application Menu
  1. Log in to the Huawei Cloud Astro Zero console and click Access Homepage. The application development page is displayed.
  2. Click in the upper left corner and choose Environments > Configuration Center.
  3. Choose Application Configuration from the main menu.
  4. On the application configuration page, select an application type (for example, App) and click an application.
  5. In the navigation pane, choose Menu Settings.
    The configured menu and its appearance in the runtime environment are shown on the right. In the runtime environment, the menus of installed application packages are read-only and cannot be edited directly.
  6. Click + next to Menu Tree and choose Add Tab.
  7. Complete the configuration and click Save.
    Table 1 Parameters for adding a tab
    Tab Type
    Select a tab type.
    • Home Tab: displays personal tasks.
    • Object tab: displays a layout of an object.
    • Standard page tab: displays a standard page.
    • Advanced page tab: displays an advanced page.
    • BPM Tab: displays a BPM.
    • Web Tab: displays the web page or page of a URL.
    • FSM Tab: displays a state machine.
    • Report Tab: displays a report.
    • Dashboard Tab: displays a dashboard.
    The parameters displayed on the page vary according to the setting of Tab Type. Set parameters based on Tab Type.
    Location
    Area for displaying tabs.
    • Home Menu: The layout selected by referring to Setting Menus of an Application will be used. For example, displayed in a side column or at the top.
    • Custom Menu Bar: Navigation tab will be available in the drop-down list box displayed after you click the username in the upper right of the application runtime portal.
    Open Way
    The way the tab will be opened.
    • Current Window: The tab will be opened in the current window.
    • New Window: The tab will be opened in a new window.
    Label
    Display name of the tab.
    Name
    Storage ID of the tab in the system.
    Icon
    Display icon of the tab.
    Page
    Page displayed after the tab is selected.
    Description of the tab.
