Adding an Assignment Diagram Element for a Flow
Functions
The assignment diagram element is for assigning values to variables. Variables can be common variables and object variables created in flows.
Using the Assignment Diagram Element
- On the flow designer, choose Logic and drag the Assignment diagram element to the canvas.
- Click the Assignment diagram element, click
, and set basic information.
Table 1 Parameter description Parameter
Label
Label of the diagram element, which is displayed on the flow design page. The system automatically assigns a value in a specific Assignmentsequence number format, with the sequence number starting at 0 for each type of diagram element.
Name
Diagram element name, which must be unique in the current flow. The naming requirements are as follows:
- Value: 1–80 characters.
- Start with a letter and can contain letters, digits, and underscores (_). It cannot end with an underscore (_).
Description of the diagram element.
Value: 1–255 characters.
- Click
and complete the configuration.
Figure 1 Configuring the assignment diagram element
Table 2 Parameters for configuring an assignment diagram element Parameter
Variable
Variable, which can be common variable, structure variable, or system variable.
Operator
Operator. Currently, =, +=, and -= are supported.
Value
Value of a common variable, struct variable, or system variable. You can also create a variable to obtain a value, or enter a constant based on the type.
If you enter a constant:
- Text type, which must be enclosed in double quotation marks, for example, "abc" and "He said Hi."
- Number and currency type. The value can be a valid number with symbols and decimal points, for example, 123.5, -12, and 12.3.
- The date format is YYYY-MM-DD, for example, 2020-10-01.
- The date and time format is YYYY-MM-DD hh:mm:ss, for example, 2020-10-01 12:00:00.
- Boolean type, which can only be true or false.
- Any type supports all basic types of formats.
