Purchasing Commercial Instances
Huawei Cloud Astro Zero's free edition offers limited resources. For commercial development, consider the standard and professional editions. The professional edition can be downgraded to the free edition, but this will restrict access to the runtime environment.
- Standard: applies to no-code application development. No coding experience is needed. This edition is ideal for enterprises. For details about how to purchase a standard instance and use the no-code capabilities, see User Guide (No Code).
- Professional: offers a low-code runtime environment (shared among tenants) and more functions and resources, building on the standard edition. It is designed for professional developers.
- Use the IAM user created in Creating a User and Authorizing the User to Use Huawei Cloud Astro Zero to purchase a standard instance.
- On the page for purchasing an instance, set related parameters and click Buy Now.
Figure 1 Purchasing a standard instance
Table 1 Parameters for purchasing a standard instance Parameter
Edition
Select the standard edition. It is ideal for enterprises to develop no-code applications.
Users
The maximum number of users, including portal users, that can be added to an instance.
Specifications
For details about the specifications, see Edition Differences.
Required Duration
Select a validity period for the instance. The value ranges from 1 month to 3 years.
- Select a payment method and click the button to pay for the order.
Figure 2 Paying an order
- After you pay for the order, click the button to return to the Huawei Cloud Astro Zero console.
- After a standard instance is created, you can access the development environment or the no-code runtime environment.
It takes several minutes to create an instance. After an instance is provisioned, the platform presets a default subdomain name for the runtime environment. The default domain name is used when the platform uses background tasks such as to-do tasks and email reminders. The default domain name can be accessed through the system parameter sys_portal_url in flows, scripts, and connectors. Enterprise members can also use this domain name to log in to the application. For details, see Accessing Huawei Cloud Astro Zero Applications as a Portal User.
Figure 3 Viewing the created instance
- (Optional) Renew or unsubscribe from a created instance.
Figure 4 Managing purchased instances
- Click Manage Runtime Environment to access the runtime environment.
- Click Upgrade to increase the number of users and upgrade the specifications of the purchased instance.
- Choose More > Renew to renew the subscription, including extending the purchase duration.
- Choose More > Check Details to view details about the current instance. In the development and runtime environments, resources created by tenants are also displayed on the details page.
- Choose More > Unsubscribe to unsubscribe from the service as prompted. The service will be degraded to the free edition. After the unsubscription, the data will not be deleted.
- Choose More > Synchronize IAM User. After deleting a user on IAM or updating the email address, you can perform this operation to synchronize the information to Huawei Cloud Astro Zero.
- Purchase a professional instance.
Figure 5 Purchasing a professional instance
Table 2 Parameters for purchasing a professional instance Parameter
Edition
Select the professional edition.
Users
Specifications
Required Duration
Select a validity period for the instance. The value ranges from 1 month to 1 year.
Figure 6 Paying an order
- After a professional instance is created, you can access the development and runtime environments.
Figure 7 Viewing the created instance
Figure 8 Procedure
