Updated on 2025-03-24 GMT+08:00
slider
Configuration Item Description
Table 1 Configuration item description
Type
Mandatory
Example
type
String
Yes
type: "slider"
Configuration item type.
value
String
No
value: "defaultValue"
Default value.
name
String
Yes
The value of this field is bidirectionally bound to the value of commProps.myString in advanceEditvm.
label
Object
No
label: {"zh_CN": "Chinese label", "en_US": "En label"}
Label of a configuration item, which needs to be internationalized.
tip
Object
No
tip: {zh_CN: "Chinese tip," en_US: "English tip"}
Tip icon. When a configuration item is complex, you can add some tip content.
noToolTip
Boolean
No
noToolTip: false
Whether the tag has el-tooltip. The default value is false.
disabled
Function | Boolean
No
disabled: true or (data, field, vm) => boolean
Whether to disable the function. You can customize the function to determine whether to disable the function based on the values of other options. If true is returned, the function is disabled.
showFunc
Function
No
showFunc: function(vm) { return vm.commProps.showTitle; }
Whether to display the configuration item. You can customize the function to determine whether to display the configuration item based on the values of other options. If true is returned, the function definition is displayed.
stepStrictly
Boolean
No
stepStrictly: false
Indicates whether only a multiple of step can be entered. The default value is false.
precision
Number
No
precision: 2
Value precision.
step
Number
No
number: 1
Counter step. The default value is 1.
hideControls
Boolean
No
hideControls: false
Whether to use the control button.
min
Number
No
min: 0
Sets the minimum value allowed by the counter. The default value is -Infinity.
max
Number
No
max: 100
Sets the maximum value allowed by the counter. The default value is Infinity.
showInput
Boolean
No
showInput: true
Indicates whether to display the text box. The default value is true.
append
String
No
append: "%"
String to be added.
Event
Table 2 Events
Event Name
Method In Configuration Item
Callback Parameter
change
change
Triggered when the value changes.
(value, data, field)
Configuration Example
The following is an example of the slider configuration. The configuration effect is shown in Figure 1.
	type: 'slider',
	value: '64%',
	label: {
		zh_CN: 'sliderstr type',
		en_US: 'sliderstr Type Example'
	append: '%',
	step: '0.01',
	stepStrictly: true,
	precision: '2',
	min: '20',
	max: '100',
	showInput: true
Figure 1 Configuration effect
