textarea
Configuration Item Description
Parameter |
Type |
Mandatory |
Example |
Description |
type |
String |
Yes |
type: "textarea" |
Configuration item type. |
value |
String |
No |
Default value. |
name |
String |
Yes |
The value of this field is bidirectionally bound to the value of commProps.myString in advanceEditvm. |
label |
Object |
No |
label: {"zh_CN": "Chinese label", "en_US": "En label"} |
Label of a configuration item, which needs to be internationalized. |
tip |
Object |
No |
tip: {zh_CN: "Chinese tip," en_US: "English tip"} |
Tip icon. When a configuration item is complex, you can add some tip content. |
noToolTip |
Boolean |
No |
noToolTip: false |
Whether the tag has el-tooltip. The default value is false. |
disabled |
Function | Boolean |
No |
disabled: true or (data, field, vm) => boolean |
Whether to disable the function. You can customize the function to determine whether to disable the function based on the values of other options. If true is returned, the function is disabled. |
showFunc |
Function |
No |
showFunc: function(vm) { return vm.commProps.showTitle; } |
Whether to display the configuration item. You can customize the function to determine whether to display the configuration item based on the values of other options. If true is returned, the function definition is displayed. |
placeholder |
String |
No |
placeholder: {"zh_CN": "Please enter," "en_US": "Please input"} |
Placeholder text in the text box. |
rows |
Number |
No |
rows: 3 |
Number of lines in the text box. |
minRows |
Number |
No |
minRows: 2 |
Minimum height of the adaptive content. |
maxRows |
Number |
No |
maxRows: 6 |
Maximum height of the adaptive content. |
Event
Event Name |
Method In Configuration Item |
Description |
Callback Parameter |
change |
change |
Triggered only when the input box loses the focus or the user presses Enter. |
(data, field) |
blur |
blur |
Triggered when the input box obtains the focus. |
(value, data, field) |
focus |
focus |
Triggered when the input box loses the focus. |
Configuration Example
The following is an example of the textarea configuration. The configuration effect is shown in Figure 1.
{ type: 'textarea', name: 'commProps.myTextarea', value: 'text type', label: { zh_CN: 'textarea type', en_US: 'textarea Type Example' }, rows: '3' }
