propertiesConfig
Field Description
The propertiesConfig is an array, which is used to store the fields related to the widget configuration items, including the data access configuration and widget configuration item.
Data Access Configuration
For details about data access configuration, see Widget Data Access.
Widget Configuration Items
The following is a configuration example. The configuration effect is shown in Figure 2. For details about widget configuration items, see Table 1.
{ migrateFrom: 'advancedSettings', headerTitle: { zh_CN: 'Data Mapping', en_US: 'Data Mapping' }, belong: 'configuration', config: [ { type: 'select', name: 'commonProps.emphasisFocus', label: { zh_CN: ''Emphasis Focus', en_US: 'Emphasis Focus' }, value: 'series', options: [ { label: { zh_CN: 'None', en_US: 'None' }, value: 'none', }, { label: { zh_CN: 'Self', en_US: 'Self' }, value: 'self', }, { label: { zh_CN: 'Series', en_US: 'Series' }, value: 'series', }, ], }, { type: 'tab', name: 'commonProps.showLabel', label: { zh_CN: 'Emphasis Focus', en_US: 'Emphasis Focus' }, value: true, options: [ { label: { zh_CN: 'Show', en_US: 'Show' }, value: true, }, { label: { zh_CN: 'Hide', en_US: 'Hide' }, value: false, }, ], }, ], },
Field |
Type |
Example |
Description |
migrateFrom |
String |
migrateFrom: "advancedSettings" |
Fixed format. After the configuration, the configuration items are filtered out on the attribute panel on the right. |
headerTitle |
Object |
headerTitle: { zh_CN: "Row Configuration", en_US: "Row Configuration" }, |
Title, which needs to be internationalized. |
belong |
String |
belong: "configuration", |
Classification to which it belongs. |
config |
Array |
config: [] |
Configuration item information saved by each object in the config array. For details about the configuration items in config, see Widget Configuration Items (Config). |
