Banner Image
Banner image refers to the display of image ads through a carousel.
On the large screen design page, drag the banner image widget from All > Media to the blank area of the canvas, as shown in Figure 1.
Card
A card wraps a chart widget. A widget consists of card elements (card title, chart, card background, and card border) and chart elements.
- Background
- Background color: Background color of the widget card.
- Border: Border of the widget. Options: no border, full border, and corner border. For full border and corner border, you can set the line type and rounded corners of the outer border of the widget.
- Style: Image display style. The options are normal, center, stretch, and tiled.
- Choose image: Use a local image as the widget background. Directories and subdirectories can be added to facilitate image management by category. JPG, JPEG, PNG, or GIF images are recommended. The size of each image cannot exceed 50 MB.
- Special effect: Widget highlighted status. Displayed by default or on page load.
- Padding: Distance between the chart in the widget and the four sides (top, bottom, left, and right) of the widget (see Figure 2). The default value is 0, indicating that the chart is stretched across the widget.
Banner Image Configuration
In the configuration, you can set the image, switch, play, and positioning display of banner images.
- Banner settings
- Image: Images for banner display.
- Image fit: Set the image filling mode. Options: fill, contain, cover, and none.
- Switchover
- Switch direction: Image switching direction, for example, horizontal or vertical.
- Switch mode: Image switching mode, such as fade out, push, and uncover.
- Autoplay
- Automatic rotation: Rotation mode, which can be manual or automatic.
- Interval: Banner interval. The value cannot be greater than 24 seconds.
- Positioning mark
- Positioning flag: Whether to display a positioning flag.
- Logo selection: Marker style, such as dot and line.
Data
In the data settings, you can set the data source of the banner image widget. For more information, see Data Access.
Interaction
In the interaction settings, you can configure interactions between the banner image widget and other widgets or pages. For details, see Interaction Configuration.
