Using IAM Identity Policies to Grant Access to ASM
To manage fine-grained permissions for your ASM resources using identity policies, use Identity and Access Management (IAM). With IAM, you can:
- Create IAM users or user groups for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing ASM resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
- Entrust a Huawei Cloud account or a cloud service to perform efficient O&M on your ASM resources.
If your Huawei Cloud account meets your permissions requirements, you can skip this section.
Figure 1 shows the process flow of identity policy-based authorization.
Before granting permissions, learn about system-defined permissions in Identity Policy-based Permissions. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
Process Flow
- On the IAM console, create an IAM user or create a user group.
Create a user or user group on the IAM console.
- Attach a system-defined identity policy (ASMReadOnlyPolicy as an example) to the user or user group.
Assign the permissions defined in the system-defined identity policy ASMReadOnlyPolicy to the user or user group, or attach the system-defined identity policy to it.
- Log in as the IAM user and verify permissions.
In the authorized region, perform the following operations:
- Choose Service List > Application Service Mesh. Click Buy Mesh on the ASM console. If a message appears indicating that you have insufficient permissions to perform the operation, ASMReadOnlyPolicy is in effect.
- Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, ASMReadOnlyPolicy is in effect.
Example Custom Identity Policies
You can create custom identity policies to supplement the system-defined identity policies of ASM. For details about actions supported in custom identity policies, see Actions Supported by Policy-based Authorization.
To create a custom identity policy, choose either visual editor or JSON.
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy grammar.
- JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Identity Policy and Attaching It to a Principal.
When creating a custom identity policy, use the Resource element to specify the resources the identity policy applies to and use the Condition element (service-specific condition keys) to control when the identity policy is in effect. For details about the supported resource types and condition keys, see Actions Supported by Identity Policy-based Authorization.
The following provides examples of custom ASM identity policies.
- Example 1: Grant permissions to create service meshes.
{ "Version": "5.0", "Statement": [ { "Effect": "Allow", "Action": [ "asm:mesh:create", "asm:mesh:createGateway" ] } ] } - Example 2: Create a custom identity policy containing multiple actions.
A custom identity policy can contain the actions of one or more services. Example identity policy containing multiple actions:
{ "Version": "5.0", "Statement": [ { "Effect": "Allow", "Action": [ "asm:mesh:create", "asm:mesh:createGateway" ] }, { "Effect": "Allow", "Action": [ "evs:volumes:create", "evs:volumes:list" ] }, { "Effect": "Allow", "Action": [ "ecs:cloudServers:createServers", "ecs:cloudServers:listServersDetails" ] } ] }
