- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
Authenticating JWT Requests on the Ingress Gateway Using ASM
This section describes how to authenticate JWT requests on the ingress gateway using ASM to ensure that users access services through the ingress gateway with a reliable access token.
Preparations
- A service mesh of version 1.13/1.15 or 1.18 has been created.
- The httpbin service that passes the diagnosis exists in the mesh. The image is httpbin, the port protocol is HTTP, and the port number is 80.
- An accessible gateway has been created for the httpbin service in the mesh.
Creating JWT Authentication
- Create a JWK.
- Visit JWT tool website, set Algorithm to RS512, and obtain the public key (PUBLIC KEY).
Figure 1 Generating a public key
- Select PEM-to-JWK (RSA Only) in the JWK to PEM Convertor online tool, enter the public key obtained in the previous step, and click submit to convert the public key into a JWK.
Figure 2 Converting the public key to a JWK
{"kty":"RSA","e":"AQAB","kid":"a78641b9-d81e-4241-b35a-71726c3fa053","n":"u1SU1LfVLPHCozMxH2Mo4lgOEePzNm0tRgeLezV6ffAt0gunVTLw7onLRnrq0_IzW7yWR7QkrmBL7jTKEn5u-qKhbwKfBstIs-bMY2Zkp18gnTxKLxoS2tFczGkPLPgizskuemMghRniWaoLcyehkd3qqGElvW_VDL5AaWTg0nLVkjRo9z-40RQzuVaE8AkAFmxZzow3x-VJYKdjykkJ0iT9wCS0DRTXu269V264Vf_3jvredZiKRkgwlL9xNAwxXFg0x_XFw005UWVRIkdgcKWTjpBP2dPwVZ4WWC-9aGVd-Gyn1o0CLelf4rEjGoXbAAEgAqeGUxrcIlbjXfbcmw"}
- Create JWT authentication.
- Log in to the ASM console and click the name of the target service mesh to go to its details page.
- In the navigation pane, choose Service Management. In the upper right corner of the list, select the namespace that your services belong to.
- Locate the httpbin service and click Security in the Operation column. In the window that slides out from the right, click JWT Authentication and then Configure now. In the displayed dialog box, set the following parameters:
- Issuer: issuer of the JWT. Set this parameter to test.
- Audience: JWT audiences who use the JWT token to access the target service. Set this parameter to ASM.
- JWKS: JWT information. Set this parameter to {"keys": [JWK created in 1]}. For example, if the JWK created in 1 is {"kty":"RSA","e":"AQAB","kid":"a78641b9-d81e-4241-b35a-71726c3****"}, the value of JWKS is {"keys": [{"kty":"RSA","e":"AQAB","kid":"a78641b9-d81e-4241-b35a-71726c3****"}]}.
Figure 3 Creating JWT authentication - Click OK.
Checking Whether JWT Authentication Takes Effect
- Use JWT tool to encode the JWT request information into a JWT token.
Enter the following JWT request information in the Decoded area. The automatically converted JWT token is displayed in the Encode area.
- HEADER: Set alg to RS512, enter kid in the JWK created in 1, and set typ to JWT.
- PAYLOAD: Set iss to test and aud to ASM. Ensure that the values are the same as the issuer and token audience configured in 2.
- VERIFY SIGNATURE: The value must be the same as the public key in 1.a.
Figure 4 Creating a JWT token - Access the httpbin service through the ingress gateway.
- Run the following commands to access the service with the JWT token created in 1:
TOKEN=JWT token created by the 1.
curl -I -H "Authorization: Bearer $TOKEN" http:// {External access address of the httpbin service}/
Expected outputs:
HTTP/1.1 200 OK server: istio-envoy date: Wed, 21 Sep 2022 03:11:48 GMT
- Run the following command to access the service with an invalid JWT token:
curl -I -H "Authorization: Bearer invalidToken" http:// {External access address of the httpbin service}/
Expected outputs:
HTTP/1.1 401 Unauthorized www-authenticate: Bearer realm="http://***.***.***.***:***/", error="invalid_token" content-length: 145 content-type: text/plain date: Wed, 21 Sep 2022 03:12:54 GMT server: istio-envoy x-envoy-upstream-service-time: 19
- Modify the JWT authentication created in 2, leave the aud empty (indicating that the service can be accessed by any services), and run the following command to access the service with the JWT token created in 1:
Expected outputs:
HTTP/1.1 200 OK server: istio-envoy date: Wed, 21 Sep 2022 03:20:07 GMT
- Run the following command to access the service without the JWT token:
curl -I http:// {External access address of the httpbin service}/
Expected outputs:
HTTP/1.1 403 Forbidden content-length: 85 content-type: text/plain date: Wed, 21 Sep 2022 03:29:31 GMT server: istio-envoy x-envoy-upstream-service-time: 6
According to the preceding outputs, the request with the correct JWT token can access the service, and the request with an incorrect JWT token or without a JWT token cannot access the service. This means the request identity authentication takes effect.
