- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
JWT Authentication Principles
JWT is an authentication mode in which the server issues tokens to the client. When a user logs in to the client using the username and password, the server generates and returns a token to the client. The client only needs to carry the token when sending a request to the server. The server verifies the token to determine whether the request is from a valid client and determines whether to return a response to the client. This method, which connects authenticated clients based on tokens in requests, solves various stateful problems of storing sessions on a server at an early stage.
In Istio, the JWT token is generated by a specific authentication service and verified by meshes, completely decoupling the authentication logic in user services and enabling applications to focus on their own services. Figure 1 shows the complete Istio-based JWT mechanism.
1. The client connects the authentication service by logging with the user name and password.
2. The authentication service verifies the username and password, generates a JWT token (including the user ID and expiration time), and signs the token with the private key of the authentication service.
3. The authentication service returns the JWT token to the client.
4. The client stores the JWT token locally for subsequent requests.
5. When requesting to another service, the client carries the JWT token and does not need to provide information such as the username and password.
6. The mesh data plane proxy intercepts the traffic and verifies the JWT token using the configured public key.
7. Once the JWT token is verified, the mesh proxy forwards the request to the server.
8. The server processes the request.
9. The server returns the response data to the mesh proxy.
10. The mesh data plane proxy forwards the response data to the caller.
The step 6 is important because the JWT authentication function is migrated from the server to the mesh proxy. The mesh data plane obtains, from the authentication policy configured by the control plane, the public key for verifying the JWT token. The public key may be one configured on the JWKS (JSON Web Key Set) or one obtained from a public key address configured by jwksUri. After obtaining the public key, the mesh proxy uses it to verify the token signed by the private key of the authentication service, decrypts the iss in the token, and verifies whether the issuer information in the authentication policy is matched. If the verification is successful, the request is sent to the application. If not, the request is rejected.
JWT Structure
JWT is of the JSON structure that contains specific declarations. Step 6 of the JWT authentication process shows the request identity can be confirmed by verifying the JSON structure. Querying the backend service is not needed. The following shows how the authentication information is carried by parsing the JWT structure.
A JWT token consists of three parts: header, payload, and signature.
- Header
Describes the JWT metadata, including the algorithm alg and type typ. alg describes the signature algorithm so that the receiver can verify the signature based on the corresponding algorithm. The default algorithm is HS256 (as follows), indicating HMAC-SHA256. typ indicates the token type. If typ is JWT, indicating that the token is of the JWT type.
{ "alg": "HS256", "typ": "JWT" }
- Payload
Stores the main content of the token. The authentication service AuthN generates related information and places the information in the token payload. The attributes of payload include:
- iss: token issuer
- aud: token audience
During JWT verification, the iss and aud will be verified to check whether they are matched with the token issuer and audience. The JWT content is not encrypted. All services that obtain the token can view the content in the token payload. You are advised not to store private information in the payload.
- Signature
Signature of the header and payload, ensuring that only the specific legitimate authentication services can issue tokens. Generally, the header and payload are converted into strings using Base64, and then the private key of the authentication service is used to sign the strings. The signature algorithm is the alg defined in the header.
# Header: { "alg": "RS512", "typ": "JWT" } # Payload { "iss": "weather@cloudnative-istio", "audience": "weather@cloudnative-istio" } # Signature RSASHA512( base64UrlEncode(header) + "." + base64UrlEncode(payload) )
The token output of the preceding structure is as follows. The three strings separated by periods (.) correspond to the header, payload, and signature of the JWT structure, respectively.
eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjQ2ODU5ODk3MDAsInZlciI6IjIuMCIsImlhdCI6MTUzMjM4OTcwMCwiaXNzIjoid2VhdGhlckBjbG91ZG5hdGl2ZS1pc3Rpby5ib29rIiwic3ViIjoid2VhdGhlckBjbG91ZG5hdGl2ZS1pc3Rpby5ib29rIn0.SEp-8qiMwI45BuBgQPH-wTHvOYxcE_jPI0wqOxEpauw
