On this page
Show all
Help Center/ Application Service Mesh/ User Guide/ Mesh Configuration/ Istio Resource Management/ Handling Policy of Resource Configuration Using IstioOperator
Updated on 2024-10-08 GMT+08:00
When Istio is installed using Istio Operator, the workloads (istiod, istio-ingressgateway, and istio-egressgateway) managed by Istio Operator need to be updated. For example, upgrade the version of the service mesh enabled for the workload, or add more istio-ingressgateway instances. You can update these workloads on the Workloads page of the CCE console.
Handling Policy
In ASM 1.8.6, to avoid configuration conflicts and ensure stable running of Istio workloads, you are advised to:
  • Define key and non-key running configurations for workloads.
    Table 1 Key running configurations of each resource type
    Workload
    Resource Type
    Item
    Applicable Version
    istiod
    istio-egressgateway
    Deployment
    spec.replicas
    Number of pods
    1.8.6 or later
    spec.strategy
    Upgrade policies
    spec.template.spec.nodeSelector
    Scheduling policies
    spec.template.spec.affinity
    Scheduling policies
    spec.template.spec.tolerations
    Scheduling policies
    spec.template.spec.containers.resources
    Resource requests and limits
    istiod
    istio-egressgateway
    Deployment
    spec.template.spec.containers.env
    Container environment variables
    1.13.9-r10, 1.15.7-r3, or later
    1.18.7-r3 or later
    istio-cni-node
    DaemonSet
    spec.updateStrategy
    Upgrade policies
    1.18.5-r1 or later
    Scheduling policies
    Scheduling policies
    Scheduling policies
    1.18.7-r3 or later
  • By default, the Istio Operator does not update key running configurations of workloads in the current cluster. Only non-key running configurations can be updated.
  • If you need to modify key running configurations, you are advised to modify them on the Workloads page of the CCE console. If you have special requirements, submit a service ticket.
