- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
Show all
Handling Policy of Resource Configuration Using YAML
You can create Istio resources on the console or using YAML on the Istio Resource Management page. To avoid configuration conflicts, you are advised to:
- Use console to maintain resources created on the console.
- Use YAML to maintain resources created by YAML.
If resources created on the console are modified using YAML, the corresponding functions on the console will be unavailable. For example, after VirtualService resources are configured using YAML, the corresponding services on the console cannot perform traffic management and grayscale release.
Handling Policy
When you edit or create Istio resources for a service on the Mesh Configuration > Istio Resource Management page, Apply YAML only at the bottom of the page is selected by default. Retain the selection and click OK, the configuration takes effect, however, some functions on the console are no longer available for the service and the resources can be maintained only in YAML mode.
If Apply YAML only is not selected, the modified configuration using YAML may conflict with some console functions.
Symptom |
Possible Cause |
On the Service Management page, the Security button of the target service is unavailable. |
The AuthorizationPolicy resource is modified using YAML. |
On the Service Management page, the Manage Traffic button of the target service is unavailable. |
The DestinationRule or VirtualService resource is modified using YAML. |
On the Service Management page, the Release button of the target service is unavailable. |
When a release task is created on the Grayscale Release page, the target service cannot be selected. |
On the Gateway Management page, the Add Route button of the target gateway is unavailable. |
Gateway resources are modified using YAML. |
When a route is added on the Gateway Management page, the target service cannot be selected. |
