Updated on 2025-03-07 GMT+08:00
Adding a Gateway
A gateway enables unified entry, traffic management, security, and service isolation.
Gateways use load balancers of ELB to provide network access. Before adding a gateway, you need to create a load balancer.
When creating a load balancer, you need to ensure that it belongs to the same VPC as the cluster. For details, see Creating a Shared Load Balancer.
  1. Log in to the ASM console and click the name of the target service mesh to go to its details page.
  2. In the navigation pane on the left, choose Gateway Management and click Add Gateway.
  3. Configure the following parameters.
    • Gateway Name
      Enter a gateway name. Enter 4 to 59 characters starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
    • Cluster
      Select the cluster that the gateway belongs to.
    • Access Mode
      • IP Version: The value can be IPv4 or DualStack. This parameter is available only when IPv6 is enabled.
      • Gateways use shared and dedicated load balancers of ELB for the access over both public and private IPv4 networks.
    • Access Entry
      • External Protocol
        Select one to match the protocol type of your service. HTTP, gRPC, TCP, TLS, and HTTPS are supported.
      • External Port
        Enter the port number exposed in the Load Balancer Service address. The port number can be specified randomly.
      • External Access Address
        The system automatically fills in the IP address of the load balancer as the service access entry. You can also change the IP address to the domain name associated with the load balancer.
      • TLS Termination
        If External Protocol is HTTPS, TLS Termination is enabled and cannot be disabled.
        If External Protocol is TLS, you can enable or disable TLS Termination. If you enable TLS termination, bind a certificate to support TLS-based data transmission encryption and authentication. If you disable TLS termination, encrypted TLS data will be directly forwarded.
      • Secret Certificate
        • When configuring a TLS protocol with TLS termination enabled, you need to bind a certificate to support TLS-based data transmission encryption and authentication.
        • When configuring the HTTPS protocol, you need to bind a secret certificate.
      • Earliest TLS Version Supported/Latest TLS Version Supported
        When configuring a TLS protocol with TLS termination enabled or an HTTPS protocol, you can select the earliest and latest TLS versions.
  4. (Optional) Configure the route parameters.
    When the access address of a request matches the forwarding rule (which consists of an external access address and URL), the request is forwarded to the corresponding target service for processing. Click . The Add Route dialog box is displayed.
    • URL Matching Rule
      • Prefix match: A URL can be accessed if its prefix is the same as the URL you set. For example, if the URL is set to /healthz, /healthz/v1 and /healthz/v2 can be accessed.
      • Full match: Only the URL that fully matches the URL you set can be accessed. For example, if the URL is set to /healthz, only /healthz can be accessed.
    • URL
      Mapping URL supported by the service, for example, /example.
    • Namespace
      Select the namespace that the gateway belongs to.
    • Target Service
      Service of the gateway. Select a value from the drop-down list box. The target service is filtered based on the corresponding gateway protocol. For details about the filtering rules, see Why Cannot I Select the Corresponding Service When Adding a Route?
      The service which configuration diagnosis fails cannot be selected. You need to fix the issues first. For details, see Fixing Items Manually or Fixing Items Automatically.
    • Access Port
      Only ports that match external protocols are displayed.
    • Rewrite
      (This parameter is configurable when the external protocol is HTTP.)
      Rewrite the HTTP URI and host/authority header before forwarding. This option is disabled by default. To enable it, configure the following parameters:
      • URI: used to rewrite the URI or prefix. If the original path is matched by prefix, the value provided in this field replaces the corresponding matched prefix.
      • Host/Authority Header: used to rewrite the HTTP host/authority header.
    • Specify Domain Name
      Configure a routing rule for a domain name of the gateway.
  5. Click OK.
    You can obtain the external network access address of the service in the Service Management page.
    Figure 1 External network access address of the service
