- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Application Service Mesh
- Buying a Service Mesh
- Mesh Management
- Service Management
- Gateway Management
- Grayscale Release
- Mesh Configuration
- Traffic Management
- Security
Best Practices
- Upgrading Data Plane Sidecars Without Service Interruption
- Service Governance for Dubbo-based Applications
- Reserving Source IP Address for Gateway Access
- Creating a Service Mesh with IPv4/IPv6 Dual Stack Enabled
- How Do I Query Application Metrics in AOM?
- Reducing the Agency Permissions of ASM Users
- Istio-ingressgateway HA Configuration
- Service Mesh Cluster
Mesh Management
- Why Cannot I Create a Mesh for My Cluster?
- Why Are Exclusive Nodes Still Exist After Istio Is Uninstalled?
- How Do I Upgrade ICAgent?
- How Do I Enable Namespace Injection for a Cluster?
- How Do I Disable Sidecar Injection for Workloads?
- What Can I Do If A Pod Cannot Be Started Due to Unready Sidecar
- How Do I Handle a Canary Upgrade Failure?
Adding a Service
- What Do I Do If an Added Gateway Does Not Take Effect?
- Why Does It Take a Long Time to Start the Demo Application in Experiencing Service Mesh in One Click?
- Why Cannot I Access the page of the Demo Application After It Is Successfully Deployed?
- Why Cannot I Select the Corresponding Service When Adding a Route?
- How Do I Inject a Sidecar for the Pod Created Using a Job or CronJob?
- Performing Grayscale Release
Managing Traffic
- Why Are the Created Clusters, Namespaces, and Applications Not Displayed on the Traffic Management Page?
- How Do I Change the Resource Requests of the istio-proxy Container?
- Does ASM Support HTTP/1.0?
- How Can I Block Access from Some IP Address Ranges or Ports for a Service Mesh?
- How Do I Configure max_concurrent_streams for a Gateway?
- How Do I Fix Compatibility Issues Between Istio CNI and Init Containers?
Monitoring Traffic
- Why Cannot I View Traffic Monitoring Data Immediately After a Pod Is Started?
- Why Are the Latency Statistics on the Dashboard Page Inaccurate?
- Why Is the Traffic Ratio Inconsistent with That in the Traffic Monitoring Chart?
- Why Can't I Find Certain Error Requests in Tracing?
- Why Cannot I Find My Service in the Traffic Monitoring Topology?
- How Do I Connect a Service Mesh to Jaeger or Zipkin for Viewing Traces?
- Videos
More Documents
- Getting Started
- User Guide
- Mesh Management
Adding a Service
Changing a Traffic Policy
You can change the settings of a configured traffic policy. For example, you can change the load balancing algorithm from Round robin to Random.
- Log in to the ASM console and click the name of the target service mesh to go to its details page.
- In the navigation pane, choose Service Management. Locate the service whose traffic policy needs to be modified and click Manage Traffic in the Operation column. In the window that slides out from the right, modify traffic policies.
- On the Load Balancing tab, click Configure now. In the displayed dialog box, change the algorithm to Random and click OK.
Figure 1 Modifying the load balancing algorithm
Parent topic: Traffic Management
