Help Center/ Application Performance Management/ User Guide(2.0)/ Application Metric Monitoring/ Application Monitoring Details/ Debugging Diagnosis/ Object Analysis
Updated on 2026-09-18 GMT+08:00
Object Analysis
Object analysis enables you to analyze the internal status of an object and view the parameter values and details of the object.
- Log in to the APM console.
- Click
on the left and choose Management & Governance > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- In the tree on the left, click
next to the target environment. - Click the Debugging Diagnosis tab.
- Click Object Analysis. The Object Analysis page is displayed. Figure 1 Object analysis
- Enter a class name, select an instance, and click Confirm. The real-time information of the instance's field is displayed. The details include the type, field name, and details.
- Click View Details in the Details column. The detailed information about the field is displayed in the right pane.
Parent topic: Debugging Diagnosis
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
