Suggestions
APM Profiler performance analysis provides suggestions. Based on the performance data, APM identifies the methods with excessively high CPU usage and provides suggestions.
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- In the tree on the left, click
next to the target environment. - Click the Profiler Performance Analysis tab.
- Click Suggestions. The Suggestions page is displayed.
Instance: Select up to one instance from the drop-down list.
Table 1 Suggestion parameters Parameter
Type
Performance issue type. Only the CPU type is available. The memory and latency types will be available later.
Performance Issue
Description of a performance issue.
Call Method
Name of the method where the issue occurs.
Number of Issues
Number of times that the performance issue occurred within a specified time range.
CPU Usage
CPU usage when the issue occurred last time.
Operation
Operations that are supported. Option: View Details.
- Click View Details in the Operation column to view suggestions. The information includes the start time, end time, issue description, status, handling procedure, and issue details. You can search for data by method path.
